Originally Posted by chadw01
Do these devices support GigE? Every GigE device I have has issues negotiating a stable Ethernet connection with both my Actiontec's and NIM100's.. they both seem to be able to support only Fast Ethernet (100Mpbs). Is this a limitation of these devices?
If I use 100Mbps ports, connectivity is great - I know the devices themselves only support up to 100, but if a 1000 device is hooked up to either, shouldn't it negotiate to the lowest speed??
I use a Rev G for main router and a Rev I for my MoCA bridge in a remote room that never had an Ethernet run.
Both of these models are 10/100/1000 ports (including WAN) and though I haven't fully tested the network speeds... I am getting just over 140Mb (max 150Mb) internet speeds on the Ethernet connection of the MoCA bridge... (I believe ~140Mb is max for MoCA 1.1)
BTW, You guys should check out this chart: http://www.dslreports.com/speak/slid...dGFydD0zMDA%3D
...from the this Thread on DSLReports: http://www.dslreports.com/forum/r266...-Router-REV.-I
...it has most of the up to date info on the various Rev's.
Lastly, here is my recent thread showing off the rewiring of my FiOS setup: http://www.avsforum.com/avs-vb/showthread.php?t=1397735
Example:
OEP32490 by MrKal_El, on Flickr
OEP32965 by MrKal_El, on Flickr
OEP32973 by MrKal_El, on Flickr
