Hi Everyone,
I recently purchased an Arcam AVR 300 and now I need to make my first speaker purchase. I have pretty much limited my choices down to two speakers:
1) A used set of Totem Forest.
2) A new set of Paradigm Studio 60 v5
I would like to get your opinions on what would pair best with the Arcam. I mostly will use them for music (80% music 20% movies).
I know the best answer is to listen to both and decide on my own. However, I have a couple of problems with this. The Totems would be purchased used, so there is no easy way to audition them. The local Paradigm dealer does not allow customers to audition the speakers at home and I think it is pointless to listen to them in store (different receiver, different inputs and different room).
If you were in this situation what speakers would you choose? Or would you do something completely different.
FYI - I listen to a very broad range of music (e.g. Pearl Jam, Norah Jones, Jazz & Blues, Christmas, Nirvana, 10,000 maniacs, Marley, even R&B and various types of Latin music) so I need something that can really kick when I need it, but also be very clean/clear when playing something more quiet and laid back. Also, I will not have a subwoofer for at least a few months.
Thanks for your help.
). Also there was the price factor. New 60v5 are at the top of my price point. This is basically the same price as used Totems, which I was told will also be OK in my living room (BTW she hates the previous versions of the Paradigms with the plastic tops, so used is out of the question).
Again, for rockers, I'd be tremendously surprised if most would prefer the Forests (in a fairly large room). Had I 5000$ I wanted to spend for speakers, I'd probably go used or ID, then B&M, and in B&M, Totem would be pretty low on the list as they have a pretty low bang for the buck value (Had 2 Totems speakers in the past...)
