Originally Posted by cbauer25
Pressing the Watch TV activity runs through the following tasks:
1) Turn on TV
2) Turn on Receiver
3) Turn on DVR
4) Set HDR44 to Zone 1
5) Set HDR44 to Source 1
If I haven't used a Zone/Source in some time, the activity fails to display the Zone1-Source1 combination.
Do you have any tips on how to fix this? Recommend input/interkey delay settings on the remote?
1) Turn on TV
2) Turn on Receiver
3) Turn on DVR
You don't need the Zone 1 portion - that is only used for the external IR input on the back. From the IR receivers in each zone, you just use the source 1-4 code. That may be your issue...
As for interference, if the blue "talkback" LED is lit, it's seeing IR - if you're not performing an IR action, that would be interference. If the light is not on, then there's no interference.
Jeff
