Has anyone tried this with a non-Harmony remote yet? I use a URC MX-3000 in my theater, and I'm currently using the Nyko IR USB receiver. I'd like to be able to add power and eject commands into my remote if possible.
It seems to me that this should be able to work with a non-Harmony remote, shouldn't it? If it receives IR commands (which are common), then I'd just need to enter the hex codes into my programming setup. I may try one out to see if I can get it to work (and return it if it doesn't), but I'd be interested to know what kind of results people are getting with a Pronto or URC.
jj
jj
.. Using the Harmony 1000 for my remote..
