Last night I played with my newly purchased Zenith CECB and experimented in exhaustive detail (yep, boring evening) on its tuner sensitivity relative to other STBs and televisions (w/ASTC tuners). And I have come to the realization that signal meters on televisions/STBs are often of questionable value, or at least display curious results. For example,
Zenith CECB - only shows a signal strength bar. Any signal falling in the lower third ("Bad") realm is unviewable. I have yet to get a signal locked at the extreme end of "Good".
Toshiba 40RV525R - a numbered signal meter. Almost every signal received is at the max value (97, .. why 97!?!). On those rare signals that fluctuate I seem to lose the picture when the value falls below 15.
Magnavox 2160a DVDR - a numbered signal meter. Nothing gets above 70. PQ deteriorates when value falls below 20.
I also have a Samsung DTBH260F, a STB with a prior generation ASTC tuner. It seems to have the most believable signal meter (using a bar chart). A couple of close, powerful stations come in at 100. Signal breakup occurs when the value falls below 20.
So I sense that these meters are not uniformly calibrated. A value of 70 on the Toshiba does not seem to correspond to the same on the Magnavox or the Zenith. It seems the only way to determine how the tuners compare in terms of sensitivity is to first understand for each tuner at about what signal level do pictures break up, then pick a weaker station and see how safe each tuner is from that stage. After all my fiddling around I can say the Zenith CECB tuner is comparable to or minutely weaker than my new Toshiba LCD. My Magnavox DVDR, which has a previous generation tuner, is clearly weaker than the Zenith ... by enough to cause pixellation on a few stations. But the Magnavox can pull in 90% of the stations reliably (I typically bring in 35-40 digital stations).
Anyway, I would be curious as to what you guys have noticed about signal meters and their accuracy.
_Lazza
PS - although it doesn't use a numbered signal meter I do like Zenith's manual scan feature for detecting weak signals and being able to fiddle with the antenna to see if I can improve the signal.
PPS - in the struggle to bring in the maximum number of viewable stations I had thought tuner sensitivity was a major factor. I'm now thinking it is a relatively minor factor compared to the reception capabilities of the antenna used. Get the right antenna set up and, by enlarge, discrepancies between the sensitivity of tuners become of negligible importance.
_Lazza
