AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › In wall rack mount... Help deciding!
post #1 of 3
Hello all!!!
I need help deciding on what rack to go with. I see most of yours, but many of you have alot more equipment than I do. I will have 6 spaces total. Would I be better off just building my own from lumber? Using sanded plywood, covering it, etc... Or buying a rack. I don't understand if half of these racks from MA come with shelf's? Or is that someting I have to buy extra.
Please help me to pick one out. I need 6 shelfs. 2 atleast 6-8 inches tall. The rest do not have to be more than 4-5 inches tall.
Any help is great, which shelfs to use with what rack, and where to buy...
Thanks in advance!!
Dustin
post #2 of 3
I would build your own, gives you more flexibility
Check out THIS thread or maybe THIS thread.
post #3 of 3
MA racks don't come with shelves unless you score one on craigslist w/shelves. The shelves are pricey, too.
In Rack terms every thing is measured in spaces or "U"s. A space is 1.75" high. I forget the exact width approximately 19". Maybe exactly. So for your 6-8" ones you'd need 4U or 5U shelves. For the others 3U, maybe 2U.
The racks can be pricey too. One option is to just do rack rails (~$50, shelves extra). I did this in my old build, the rails are described as rear rails, and labeled RR and then a number of spaces. RR42 or RR35 are common. I think mine was 35. You can see pics here:
http://www.avsforum.com/avs-vb/showt...=#post10905163
MA style racks tend to cost more than DIY, but there is a coolness to them.
