Today's been the 26th day since I applied my green glue drywall and I haven't noticed ANY difference.
Just to give you some brief details, I share 1 common wall with a neighbor who plays the drums. I didn't think the green glue would completely eliminate the noise, but I thought it would at least improve it a LITTLE bit, and it hasn't. One issue might be that I have crown molding on my walls but when I talked to the CSR's at soundisolationstore.com, they told me that if I put the green glue wall up without taking off the crown molding, sound isolation might suffer a little bit, but it should still be an improvement.
Also, I know flanking might be an issue, but when the drums are playing, I can put my hand up on the green glue wall and I can feel it vibrate. Also, when I slap the wall it doesn't sound 'solid'.... It still sounds just as hollow as it did before the green glue. I'm not sure what I did wrong, but if any of you can come up with any ideas, I'd be all ears. Thanks.
