AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Lexicon MC1 diagnostics faults
post #1 of 8
My Lexicon MC1 decided to go through diagnostics checks again and again instead of starting up.
I have just shut off power to it for a while...hope that resets it.
anyone know what to look for?
Scot
post #2 of 8
Pull all the connections before you "reboot".
post #3 of 8
I will try this today.
as of last night, I did not even get the diagnostics message...its black, and no lights regardless of which button i press.
post #4 of 8
Sounds like my Vizio.
post #5 of 8
DEAD!
Rats!
oh well...anyone want to break it open to see whats inside?
post #6 of 8
Scot
Mine just started doing the same thing. I recently replaced the power supply, so I don't think that is the issue.
Is there a hardware reset of some sort that might help?
Is there a battery in the unit that might be dying?
post #7 of 8
sure
post #8 of 8
well it happened again...
now if i can just remember where I brought it to get it fixed last time.
Scott
