I have implemented a digital crossover network in my PC. Depending upon configuration, it can input two channels and output as many as eight. I want to send the eight output channels of LPCM to an AV receiver via HDMI. This is totally unprotected audio content -- it may come from CD, in which case it was originally 2 channel 44100 Hz, or from A/D converters, in which case it was 2 channel at whatever sampling rate I choose.
I have installed a Gigabyte HD 4350 video card along with the Realtek 2.23 HDMI driver. The receiver is a Yamaha RX-V465. No matter how many channels I attempt to send and no matter what sampling rate, the receiver always reports the signal format as 2-channel 48 kHz LPCM. I can listen to the "front" channel outputs on the Yamaha, so audio is definitely being passed. The receiver just doesn't recognize any of the other channels.
What do I have to do in order to send 8 channels of unprotected LPCM over HDMI with this hardware? Is there some hidden configuration parameter that I have failed to set?
OS is Windows XP sp3; crossover is implemented under ASIO4ALL (WDM-KS).
