AVS › AVS Forum › Audio › Speakers › Center Channel Speaker (bar)
post #1 of 9
I am currently using Orb mods for 5.1 with mod 2 in center. I am thinking about getting a new center channel speaker. Any recommendation as to center channel (preferably a 8-10 inch bar) that would look good with Orb Spheres around and Pioneer KRP 600M display.
Any ideas ? Budget under $400..
post #2 of 9
You're not happy with the center channel output of your Orb system ?
post #3 of 9
I am not sure if I completely have the setup right. Most of the times, the dialogues get lost in the surround sounds. I have Mod2 in the center & Mod 1s as surround. I have not tried these in my new house yet. I will need to hook it up. Since it is a bigger room, I am looking around to see if there is a center channel I could get and make make front left & right as Mod2.
One other option I am exploring was getting a new set of front 3 and use the current mods as "front high" (left & right mod2) since I ordered a Onkyo Sr607 dolby prologic IIz receiver.
post #4 of 9
I'd be interested in suggestions for replacement senters as well - I've got the same issue with my Orb Mod2 setup.
post #5 of 9
I am glad it is not just me... Is your setup Mod2 or Mod1 for surround ?
Any ideas for center channel upgrades.. Any Orb lovers our there seeing the same problem????
post #6 of 9
I'm wondering if Orb lovers are in love with their size irrespective of the limitations that the divers they use in the all important center channel. Experiment with suggestions here, but a different speaker system with fewer driver compromises may be the ultimate solution for larger areas.
post #7 of 9
Have you considered going to a Mod4?
post #8 of 9
Mine are all Mod2.
post #9 of 9
I am so tempted to go Mod 4 because of the pretty looks, but not sure how the performance would be.
I was thinking about Mirage or Definitive Center channels... Any thoughts??
  Back to Forum: Speakers
