Originally Posted by
YOMEGAS
Thanks. I already adjusted my tv to some great game settings on standard. After calibrating my LG LX9500 I saw how my games should look so I adjusted from that image. This Samsung gives me a little deeper colors due to its a plasma so I adjusted the set on standard with that in mind.
@jameskollar
Game mode takes away from the picture quality no matter how you adjust it. With my settings my lag is around 38ms which is excellent and I am still unstoppable in any online shooter. Remember all lcd's except for the LG LX9500 has bad input lag. On average its around 50ms or higher even on game mode. On my LX9500 the lag is also at 40ms due to my settings but it can get a little lower. Input lag will only effect you the most in games like rock band. Unless you have a tube television with component cables input, lag will always exist due to the HDMI port is not fast enough and the tv reprocesses the image to give you a great picture. These two factors gives you your input lag.
Not wanting to start an argument, just discussing. We are talking about the Sammy plasmas in this thread, While I was not able to find out the exact numbers for B800 series, I did find the numbers for the C7000 plasmas which is highlighted below. The numbers came from
here (scroll down a bit to see the relevant post and a link to tests for other TVs). Since the C series are newer I would expect the older Samsungs to have similar numbers. In fact, I had a Sammy DLP that had the same overall lag (110ms) but did not have a game mode. The thing is, game mode bypasses a lot of the lag producing preprocessing hardware reducing lag on this series and from what I have read there is no other way to bypass this processing except game mode. And you are right, it does reduce PQ.
That said, why would anyone play games on this series of plasma unless you intend to replace it? The screens are subject to burn in. I know because I have a favorite news channel I watch regularly that has a bright white rectangular bug that has caused permanent burn-in. No amount of scrolling screen will get rid of it. Watch out for those HUDs.
Brand Model Standard Game mode
Panasonic TX-L42D25E 20 ms 23 ms
Panasonic TX-P37X20 20 ms 13 ms
Panasonic TX-P42G20 43 ms 30 ms
Panasonic TX-P42V20 23 ms 20 ms
Panasonic TX-P42X20E 17 ms 20 ms
Panasonic TX-P50G20 47 ms 17 ms
Panasonic TX-P50VT20 37 ms 17 ms
Panasonic TX-P50X20 27 ms 17 ms
Sharp LC-22LE320E 17 ms 17 ms
Sharp LC-40LE820 140 ms 17 ms
Sharp LC-42SH7 30 ms 30 ms
Sharp LC-46LE810 143 ms 30 ms
Sharp LC-46LE820 100 ms 13 ms
Sharp LC-52LE820 143 ms 37 ms
Toshiba 37RV685D 30 ms 5 ms
LG 32 LD358 13 ms 8 ms
LG 37LE5308 57 ms 33 ms
LG 37LE5800 67 ms 50 ms
LG 42 LD458 20 ms 17 ms
LG 42 SL9000 33 ms 20 ms
LG 47 LX9800 117 ms 103 ms
LG 50 PK980 43 ms 43 ms
Philips 40PFL5605H 77 ms 10 ms
Samsung 32 C5100 8 ms 8 ms
Samsung 32 C6000 100 ms 47 ms
Samsung 32 C6500 107 ms 47 ms
Samsung 32 C6510 100 ms 43 ms
Samsung 37 C5100 17 ms 17 ms
Samsung 40 C6000 100 ms 47 ms
Samsung 40 C6500 110 ms 50 ms
Samsung 40 C7000 93 ms 43 ms
Samsung 40 C7000 3D 43 ms
Samsung 40 C8000 100 ms 50 ms
Samsung 40 C8000 No Dimm 30 ms
Samsung 55 C7000 100 ms 33 ms
Samsung PS50C530 33 ms 17 ms
Samsung PS50C7000 103 ms 13 ms
Sony KDL-32EX600 37 ms 23 ms
Sony KDL-32EX700 60 ms 33 ms
Sony KDL-32NX500 13 ms 13 ms
Sony KDL-37EX500 30 ms 23 ms
Sony KDL-40BX400 20 ms 13 ms
Sony KDL-40NX700 60 ms 33 ms
Sony KDL-46EX402 13 ms 10 ms
Sony KDL-46EX700 77 ms 43 ms
Sony KDL-46NX700 63 ms 50 ms
Sony KDL-52NX800 70 ms 30 ms
