Originally Posted by Hunter
Hi, Michael -
I don't yet know what you have. But just to be clear: please note that I wrote that you can't see the problems with the 3d/deinterlacing process in still frames. It is during normal playback when the artifacts are produced.
The X0 actually has three available signal sources -
S-Video - the Composite signal is separated by the 3D filter, processed and the two components (Y and C) are output through the S-Video jack.
Composite RCA - the Composite signal is separated by the 3D filter for the purpose of implementing noise reduction as accessed through the settings menu. After the noise reduction is performed the Y and C signals are (re)combined into Composite and output through the Composite RCA jack.
Composite BNC - the Composite signal from the disc is passed along directly to the Composite BNC jack. There is no processing - the settings do not affect this Composite signal.
That is the big feature of the X0. It is virtually unique in most laserdisc machines; especially the latter-day higher-end models.
It is definitely unique among the last-generation narrow-wavelength laser players (developed for HD Muse playback).
So the reason for the Y/C filter after the X0 is to get the best Composite signal possible into the best and/or purest Y/C filter possible. There are a few excellent 2D filters - outboard and onboard in the best video processors - that are not compromised by the inevitable loss of resolution, color shift, and ringing resulting from noise reduction.
Pls check PM. Thanks.
Hi, Michael -
so which external 2D comb filter is the best ?
I've got three here, 2 Entechs and the Alchemy VRS
all of them don't even come close to the X0.
any other ones you can recommend ?
Michael
