Hi,
I have a McIntosh MLD-7020 laserdisc player. Its a lightly modified Pioneer CLD-97. The mods I noticed so far are RF out for AC-3 and Digital Video Noise Reduction on/off switch (opposed to always "on" on CLD-97).
I have a few questions in my mind. I am not sure if they would bring any improvement to the picture quality but i will ask away anyway.
I will be buying a Denon AVP-A1HDCI pre-amp which uses a 3d none-adaptive comb filter and HQV Realta scaler & de-interlacer chips for VP.
Possible set-ups:
1. Connect MLD-7020 to AVP with Composite.
2. Connect MLD-7020 to AVP with S-Video.
3. Buy an Entech SVSI-1 2D Comb-filter(I have read that Entech is one of the best comb-filter ever made). Connect MLD-7020 to Entech with composite. Connect Entech to AVP with S-Video.
4. Buy a VP which is geared towards analog sources like LD players(mostlikely something from late 90' or early 00' i.e. Faroudja VRS) connect MLD to VP with composite .connect the VP to AVP with component.
5. Buy and Entech SVSI-1 and a VP.Connect MLD to Entech with composite. Connect Entech to VP with S-video. Connect VP to AVP with component.
I am almost certain that the first 2 will not improve the picture much due to the mediocre 3d comb filter used in the Denon AVP and McIntosh LD player.
3rd option could give promising results since entech is a very good comb filter and Denon's HQV realta implementation is a very fine VP for de-interlacing and scaling.
4th and 5th options ; I dont have much clue. seems like too much processing going on but those used VPs are not too expensive nowadays, if they are going to add anything i will give them a try.
final note: the value of the MLD-7020 is 600-800 USD. I know a good shape entech svsi-1 will not be less than 150 USD. those old VPs go for 150-350usd. all together 1000-1200 USD value(LD player + comb filter + VP)
if the combination of those above 2 or 3 aproaches close to 2000USD, I have seen several HLD-X9's go for 1700-1900+shipping. so they would not make much sence. Please make recommendations based on experiences with such electronics but not on theory and keep the cost accourding to the facts above.
thank you in advance
Possible set-ups:
