Originally Posted by Hunter
This is just w.r.o.n.g. on both claims.
If you are basing this on a color bar frame, please view something other than a static, slightly incorrect test pattern.
With ALL respect - if you want to debate this (and I am fine with that
) then we need to go over setup and equipment in detail, including software.
I will state without any qualification that, with a composite source, the Entech is superior to ANY other Y/C filter when any type of deinterlacing, upscaling, or other processing of the video signal.
This is especially true of the SVSI-1. While still applicable I am not quite as enthusiastic about the CVSI-1 in all circumstances.
It depends greatly upon the player upgrade. Other factors would be the player output format and the display equipment.
And FWIW I'll take the other side ...
The best way to improve the performance of any good LD player is with a Y/C filter that precludes or lessens the ill-effects of composite-to-HD processing.
If you are basing this on a color bar frame, please view something other than a static, slightly incorrect test pattern.With ALL respect - if you want to debate this (and I am fine with that
) then we need to go over setup and equipment in detail, including software.I will state without any qualification that, with a composite source, the Entech is superior to ANY other Y/C filter when any type of deinterlacing, upscaling, or other processing of the video signal.
Okay now what? I was sure a Y/C comb filter would help with my laserdiscs. Then I was basically told no way. Now we have a resounding yes. For $100 I would love to get one. $200 plus shipping? Maybe?
Other's opinions? Josh Z?
