I've got an InFocus IN72 DLP projector. Had it for just over two years now so it's definitely out of warranty. It's been working fine until this past weekend. It is a ceiling-mount unit and I took it down to let a friend borrow it. (Yes, it is someone who would take care of it so don't even ask
Anyway, when he hooked it up he said it had 3 or 4 vertical bars on the right-hand side of the screen. If you move the projector at all, then one (or some) of the bars will go away. I got it back from him and put it on my ceiling mount. Sure enough it was doing the same thing for me. The picture is there...it just has these black vertical bars that span from one side to almost the middle of the screen.
I called InFocus and described the problem. The guy was pretty nice and told me it sounds like a "banding" issue. He quoted me $379 for repair plus $30 for shipping. I think I only paid $399 for it when I got it. I found this thread where everyone says it's basically garbage.
But I also found this link that says banding doesn't happen to DLP projectors.
Can anyone help shed some light on this for me? It only has around 260 hours on the lamp. I tried searching for information on banding, but I didn't find very much that was helpful.
Thanks in advance!
).Anyway, when he hooked it up he said it had 3 or 4 vertical bars on the right-hand side of the screen. If you move the projector at all, then one (or some) of the bars will go away. I got it back from him and put it on my ceiling mount. Sure enough it was doing the same thing for me. The picture is there...it just has these black vertical bars that span from one side to almost the middle of the screen.
Thanks in advance!
