Originally Posted by Will Munshower
Folks,
Just an open statement to those of you with clouding and/or flashlighting issues. I use bias lighting behind my Z. I haven't mounted the TV because of this. I use a 36" fluorescent D6500 aquarium lamp, mounted vertically behind the TV.
There are many articles on AVS about the subject. It also helps a lot with eye strain. I highly recommend it.
However, depending on the color of the wall behind the set, it can be problematic if you're wife made you paint it a funky color. I was 'permitted' to use a neutral gray on the wall with the TV. Think Philips Ambi-light (I think that's what it is called), that actually works. :-)
Will
Folks,
Will
Wow, I hadn't thought of that Will. Thanks for the idea!
I certainly intend to try and have Sony fix my set, but just in case not, I will certainly keep this in mind, and I may do it anyway.
It would be very easy to implement in my setup too.
I wonder how I could get it to automatically turn on and off with the tv... any advice?
