ISF Calibration performed after installing Sony's aa0153pn firmware.
Equipment utilized:
- Eyeone Pro & Sencore OTC1000
- CalMAN DPG1000 Digital Pattern Generator
- CalMAN Pro Software
This calibration was performed in a completely darkened room.
Variances can be found within the same brand and model, and your viewing environment/lighting can differ from mine. My settings can be used as a starting point, but tweak where necessary. - Enjoy.
*Note, I only use one setting since my AVR does the switching of various sources, and U utilize only one HDMI input on the display.
Screen Aspect Full Pixel
Picture Mode .........................Custom
Scene ..................................General
Screen Aspect .......................Full, with "Full Pixel"
Backlight ..............................2
Picture .................................90
Brightness ............................
49
Color ...................................
38
Hue .....................................0
Color Temperature .................Warm 2
Sharpness ............................1
Noise Reduction ....................Off
MPEG Noise Reduction ............Off
MotionFlow ..........................Off
CineMotion ...........................Off
ADVANCED SECTION
Black Corrector .....................Off
ACE ....................................Off
Gamma ................................0
Auto Light Limiter ..................Off
Clear White ..........................Off
WHITE BALANCE
Red Gain .............................-11
Green Gain ............................-7
Blue Gain ..............................-5
Red Bias................................3
Green Bias ............................5
Blue Bias ..............................4
**** I listed MotionFlow & Cinemotion as off for Blu ray, but when watching cable, I tend to leave Motionflow on Standard, and Cinemotion on Auto 2. Your mileage may vary. ****09/15/10 - Interesting find. Using Spears & Musil Disc, and the low pluge pattern.....Brightness set at 51 and I can make out the checkboard background. At 50 I couldn't, but then at 49 I could see it again.
Decided to drop it to 49 and found a very slight improvement in black and shadow detail, so I'm using 49. Also dropped color from 40 to 38, as color seems more natural.
CalMAN Report
June 6 2010 Graph.pdf 116.9501953125k . file
June 6 2010 KDL46Z5100.pdf 105.203125k . file
6-6-2010 Report.pdf 170.8759765625k . file
