Originally Posted by
dsskid
Good afternoon.
For Screen Aspect....
- Hit the "Home" button on your remote.
- Scroll to left as far as you can go on the TV Home Menu/XMB™(Xross Media Bar).
- Select "Picture & Display", "Screen Settings"
- Under "Display Area", is where you'll find "Full Pixel" (when watching HD material).
"Full Pixel" mode provides dot-by-dot mapping of the HD signal, and therefore, pixel adjustment wouldn't be available when "Full Pixel" mode is engaged.
http://esupport.sony.com/referencebo...ttings03a.html
Hopefully I've answered your questions clearly.
Best
-John
John (or anyone else that may help),
I just got a 52Z5100 setup today and now playing with the settings. I can get into the Display Area settings but only find Normal, -1, and -2, but no Full Pixel.
Under Display Area, I've got:
Wide Mode = Full
Auto Wide = On
4:3 Default = Normal
Auto Display Area = Off
Display Area = -1 (default setting)
Screen Position = unavailable
Vertical Size = unavailable
What must I change to be able to find "Full Pixel"? I downloaded the latest 153 software update and still couldn't get an option for it.
John
P.S. Also using John's picture settings. MUCH better than defaults. Only issue I seemed to have was some yellowing of very select faces... notably on Kansas St.'s coach Frank Martin. May have to fiddle a smidge with something there, but all else is fantastic. Any EASY way to try to limit the yellowish faces without messing much with the settings since everything else looks good? Also set-up our 1st Blu-ray player and just... wow!!!
