Originally Posted by videobruce
There seems to be alot of Bruces' here.
Thanks and welcome to the forum.
rightintel; ASAIK, the lamp only has one 'setting'. It does not vary in output unlike some other manufactures (some Samsung and Toshiba models for example). The 'picture' settings might adjust the 'iris' to reduce the amount of light that hits the DMD, but that's it.
Hours vary from a couple thousand to over 9,000. It's a crap shoot on how much you get.
As far as where to get a replacement, I don't know what to tell you since I haven't had to replace the lamp yet (knock on wood) other than I would just get the lamp irself, not the whole assembly.
The lamp on my 73-735 has 2 settings. Standard and Bright.
