Originally Posted by freelancer1988
LATE UPDATE: I got the TV tore apart, replaced the DLP chip and cleaned everything up and made sure all my fans were working. TV looks brilliant. My bulb was kinda dim so I replaced it with a cheap Amazon bulb... My mistake... It popped... twice... Now the guy is telling me it has to be my TV. Put the old OSRAM original dim bulb back in and no problems.... Ordering a NEW OSRAM e22h 150/180 bulb and hopefully that will solve the problem.
New bulb, solved all problems. It is like new and can't be happier.
I was too excited. And yes, send them your bill. The light engine they replaced under warranty was $900.
