Originally Posted by
videobruce
Just how large are these "dots"? If these are barely noticeable unless you are close, those are dead pixels in the DMD and the only solution is to replace it (the whole LE).
Hmm well they are like a pin head size. You can clearly see them from where I sit to watch the tv. When you turn the TV off, you can actually count them
When I am watching the TV, you can see them form actually. First you will see a flicker...then the light starts, then it becomes a solid white dot. At first I thought it was dust, but I have taken the LE apart, before I even read your guide, and I did not see any difference. I read the Samsungs dlp threads about white dots, and it seems the light engine is dead.
I have a deal to get a 65737 new for 886$. Is it worth upgrading to the newer models then get a warranty ?
Or can I replace the LE cheap ?
