AVS › AVS Forum › Display Devices › Rear Projection Units › HELP PLS: Mitsubishi ws-65513 reset code
post #1 of 4
i am in need of the reset code for a mitsubishi ws-65513. If you have it or know where I can find this code, please let me know.
Any information is more than appreciated.
Thanks in advanced!
post #2 of 4
MENU 0370, select Initial press enter, wait for it to finish, press RESET on front panel.
post #3 of 4
^^^ Thank you very much.
The TV is at my fiance's house. I will try it later today, and I'll let you if it works. Thank you!
post #4 of 4
BTW, You also gave me the code for my Mitsubishi 73" last month when I had the same problem!!
You my friend, are a life saver!
  Back to Forum: Rear Projection Units
