Originally Posted by
audiovideogeek
I think that the product reliability/quality is really dependent on the quality control in place at the factories that the products are built in.
True, in some circumstances, but I don't think China is there, yet. Chinese quality is generally an oxymoron. It's almost impossible not to buy Chinese products, but when it comes to something expensive (for my budget) I plan to rely on for years, I'll look elsewhere if I have a choice. My XBOX 360 and PS3 are Chinese, and I would've paid $100 more each, if they were made in Japan. Besides, I'm really not fond of the Chinese government.
audiovideogeek
Yamaha AVRs are made in Malaysia AFAIK
I know my RX-V2600 was made in Malaysia, but I'm still curious about the new, low end receivers.
Thanks for the links, by the way!
It's not that I absolutely have to have this years receiver, but I loved my old Denon AVR-2500. It had the Apple II-like on-screen display, which was OK for 1995, but it seems like Denon's display is still outdated. I was hoping the new versions are updated, and I believe they are. I was burned on my last purchase of a "future proof" receiver (the Yamaha), and I'm trying my best not to get burned again. You have to admit that it's a confusing time to buy a receiver. Most people don't find out about the limitations until later. The specs don't tell the whole story, unless you dig through this forum. For instance, even though my XBOX can pass a 1080p signal through component, most receivers won't convert this to 1080p HDMI. I'd have to plug the components into my TV (which may or may not accept 1080p through component-doubtful), then run a digital optical wire to the receiver, which may or may not allow this.
The Pioneer SC05 looks like a great deal, but I'd really like to get Anchor Bay video processing. My Oppo has Faroudja DCDi, so if I can be patient and get a smokin' deal on a Yamaha RX-V3900, that would be ideal. That thing looks amazing by my standards, and I'll never fully explore its capabilities.
Which brings me to another problem I have with receivers...Why don't the manufacturers design feature packed receivers with great amps and video processing technology that don't have added "features," like controlling A/V systems in a 10 bedroom mansion while cleaning your swimming pool and monitoring the security system in your home? It reminds me of cable companies charging you for all these garbage channels, just so you can access one or two you really want.
I also noticed that Pioneer has opted to switch to a blue display like Yamaha has done. Some people are upset about this, but I like the blue.
Someone provided a link to a soon to be released Yamaha RX-V1065, but the digital optical and coaxial are fixed, and can't be assigned to anything else. Stupid. This would be a problem for me, because my Oppo uses a DVI-HDMI adapter, so I'd be limited to standard RCA connections.
I guess I'm just going to be patient for now.
