Manny's basement theater
post #1 of 926
Hello AVS members,
I'm new to this forum stuff but need some suggestions.
My HT is 23' x 24' with only 7'6" ceiling height. Not ideal theater size...
I thought I had just finished it but I'm upgrading equipment and screen.
---Update Jan.27th 2010---
post #2 of 926
pics of old theater
pic of new HT version2
post #3 of 926
I ordered last week my new SMX 140" 2.35 AT screen to replace my Elite screen. I just picked up Anthem D2v to replace Anthem AVM50.
Also picked up Anthem MCA20 & MCA50 to replace 7channel Marantz amp.
My question is all my equipment will be placed underneath screen in cabinets.
I'm planning on purchasing another JL f113 sub and place them behind the screen. Will the subs effect my equipment in anyway?
post #4 of 926
some pics of old screen
Attachment 143473
Attachment 143474
post #5 of 926
Nice v1.0 Manny. In what way do you think the subs might effect your gear? Also, did I miss a riser?
CD
post #6 of 926
CD
I keep thinking that the vibration might damaged devices and make the BD player skip... maybe I'm being crazy
I didn't build a riser due to I wanted a flush screen look and I don't think I have the headroom.
The bottom of the screen frame will be 18" off the carpet floor.
Also, on Monday I built a riser for the back row seating. I will post pics this weekend....
Thanks for the reply
post #7 of 926
Give us a little more information, please. And also take a look at how to post pics so we don't have to clip on them. (we're lazy here)
So far, it sounds like you have some great equipment.
post #8 of 926
I'm trying to figure out how to load them up. Some of my pics are stored on windows vista picture holder. I keep getting errors.
The room itself was finished about a month ago and redoing most of it little by little. My wife complains that I live in the basement, I tell her its a work in progress
Room was framed with 2x4 metal studs and QuietRok and both sides. Quietrok was 1 1/2" thick and a real pain to cut. Ceiling is 2x2 armstrong drop celing which I paint black. My first plan was to cover walls with GOM fabric walls bt I changes my mind and made panels 3rows high by 2rows wide.
The front of the theater has two closets which house all my dvds and blurays.
post #9 of 926
PIC OF MY FIRST PANELS
post #10 of 926
You have so much space you could do an equipment storage on the side wall with the door. Maybe a low-boy cabinet black finish with blacked out glass doors.
You have a classic looking space and you need something euro-modern to compliment.
post #11 of 926
You recommend moving my equipment to the side wall(right)
I was trying to keep the amps and processor close to the speakers(LCR) because of the long lenght of speaker wire. I justed picked up 3-10ft monster cable speaker wire. My first plan was to put equipment in the left front side closet but I would need 25ft cable....
Another mistake I made was the shape and size of the room. Frame it before I joined the great forum
post #12 of 926
here is pic of my inexpensive Elite screen which will be replaced by SMX 140" AT screen.Hopefully next week it arrives
post #13 of 926
here is a shot of were I was planning on putting my new equipment. I purchased more cabinets to make it all line up. Doors will be made and cover with black GOM
post #14 of 926
back of theater before I built riser for back row. will take pic tonight. My rear Aerial speaker I love them
post #15 of 926
HERE IS MY OTHER SETUP
73" MITS TV, AVM50V, REVEL F32S,REVEL CENTER, SUNFIRE TRUSUB,MCA20,MCA50,PS AUDIO POWERPLANT,DENON DVD,PIONEER BD. ANTHEM'S ARC KIT MADE THIS ROOM SOUND GREAT
post #16 of 926
Wow, you have a great looking contemporary/modern home with some excellent A/V to boot.
What projector do you have?
post #17 of 926
Thanks John !!!
I finished building my home about a year ago, it took about 1 1/2 to complete.what I'm I talking about its never a done project
HT projector is a Panny pt-ae3000u its brand new but looking thru the forum I'm thinking of upgrading. But right now I need to take it easy on the spending
post #18 of 926
Hi Manny,
BUILD THE RISER!!! I have 7' 7' ceilings and I have a 12" riser for the back row. My screen if flush with front false wall @ 126" 16:9. Trust me, you can get away with it.
BTW, you're off to a GREAT start!! Keep going.
What part of Jersey are you in?
post #19 of 926
Thanks Chucky!
I just finished building the riser for second row here is pic
post #20 of 926
I changed the walls a bit. the other color didn't do anything for me.
darker blue more contrast with panels I made. Panels are 1x4 pine routed 45 degree angle on all edges. inspiration thru this forum
post #21 of 926
Originally Posted by chucky08016 View Post
Hi Manny,
Chucky I'm from south jersey...
Any pics of your setup?
post #22 of 926
other side
new equipment
equipment rack from family room setup
post #23 of 926
I was thinking about swampin out the first row sofa with brown theater seats. Maybe relocating the sofa...Any ideas
post #24 of 926
Excuse me .... ah, Zeus is Greek. Maximus is Latin. Don't you mean Jupiter Maximus, or more correctly Jupiter Optimus Maximus?*
Nice large room.
*Six years of Latin, 0 years of Greek ... I had to say something.
post #25 of 926
Chucky I'm from north jersey Union Area...
I'm in South Jersey... Burlington.
Here are some pics. They're not the best quality. I'm currently going through a speaker upgrade at the moment going from (3) JBL E100's and (4) JBL E50's to a full line of actual commercial cinema speakers.
Because of the new speakers, I had to redo the whole front wall which is the reason why the room looks very unfinished. Walls are temporarily painted just so that we have use of the room while the upgrade is taking place.
The pic with my father-in-law was photoshopped using 2 separate pics from the same angle just to give you an idea of the screen size and detail. That is the actual image from the projector with the lights off.
Room is 13'W x 25'D x 7'7"H
Riser is 10'W x 5'D x 1'H
post #26 of 926
Nice large room.
correct you are... name comes from my two dogs, ST.Bernard & Daschund.
Thanks! large room but needs to be tweeked still
post #27 of 926
Sweet Home Theater!!!
really like your screen wall, grab some ideas.
Love your seats, must be super comfy
Did you buy them somewhere local?
Manny
post #28 of 926
question? what is the prefered speaker cable to use? I've always like using the preterminated speaker cable ((MIT, Nordst,Monster REference).
Planning on my equpment to one of the side closets. L&R speaker are Monitor Gold 60s and center Areial Acoustic CC3. It cable would be around 20ft long...
suggestions
post #29 of 926
Manny
Try http://www.rtheaters.com/ . He's located in Marlboro, NJ and although I did not buy from him, he has the very best customer service.
Mine were ordered from someone out of state in South Carolina if I remember correctly.
As for the speaker cable, I just goto www.monoprice.com .
Here's a link for speaker cables from them:
http://www.monoprice.com/products/su...02&cp_id=10239
They have some of the best prices around. Just buy from them and terminate yourself saving you ALOT of money.
post #30 of 926
Thanks Chuck!
I've order from monoprice before guess I'll look in to the 12awg speaker wire
Also thanks for the tip on the theater seats that have some great stuff.
