Originally Posted by
kouasupra
I've already run MCACC, and there is some improvement but not much. My volume control is still low and I'm not too happy about that. I'll try the crossover at 80hz and see how that work.
How big is your room? Also, what gains did MCACC apply to each of your channels? The speakers I am using do not have a high sensitivity (82dB) and if I go over -20 it gets very loud. However, MCACC added anywhere from +6 to +8 dB to each of my channel levels, which means that a comfortable listening level of -25dB is really an overall gain of -18dB or so.
If MCACC applied large negative gains to your channel levels, a simple workaround is to increase each channel by 2 to 3 dB. This will increase your overall volume at a lower overall gain, and maybe get you the results you are looking for.
tnkgill
Hello All....
This forum has been a lifesaver!!! Since the manual is written so poorly, this space has been my first source for answers....
Does anyone have any general recommendations in the auto surround/advanced surround/direct settings that they particularly like when watching blu-ray with straight HDMI connections??? Same question with satellite (DTV or Dish) input???
Thanks in advance...
I am happy leaving the 919 set to Pro Logic IIx - Movie for just about everything (although this may be due to laziness). It doesn't do too much post-processing, and it will matrix any stereo or 5.1 source into 7.1, more or less. Definitely experiment though, pick a Blu-ray that you are pretty familiar with and cycle between the different codecs and just go with whichever you like. It is very subjective.
