Originally Posted by
tnkgill
Wow the more you look through this manual and set this reciever up, the more questions are generated...
1. What is the frequency sampling rate capabililties of this receiver??? I have a blu ray player that can transmit 48, 96 and 192 khz signals. My status says the receiver is at 48 khz. Does it have the capacity to sample at a higher rate???
As usual, a great product (the 919/1019) is given a huge disservice by a bad manual. From page 58 of the manual, in a note at the bottom of the page:
This receiver can only play back Dolby Digital, PCM (32 kHz to 192 kHz), DTS (including DTS 96/24) and WMA9 Pro
digital signal formats. The compatible signals via the HDMI terminals are: Dolby Digital, DTS, WMA9 Pro, PCM (32
kHz to 192 kHz), Dolby TrueHD, Dolby Digital Plus, DTS-EXPRESS, DTS-HD Master Audio, SACD and DVD Audio
(including 192 kHz). With other digital signal formats, set to ANALOG (the MULTI CH IN and TUNER).
You may get digital noise when a LD or CD player compatible with DTS is playing an analog signal. To prevent noise,
make the proper digital connections (page 29) and set the signal input to DIGITAL.
Some DVD players don't output DTS signals. For more details, refer to the instruction manual supplied with your
DVD player.
Note that it doesn't give a full matrix of sampling rate and input signal type, but it is capable of handling all of the input frequencies you mentioned.
tnkgill
2. Is it possible to turn the video scaler off??? My blu ray player upconverts (non blu ray) media and my plasma (Panny V10) also upconverts...
Thanks!!!
I believe it's:
(lower right side of the remote)
VIDEO PARAMETER
V.CONV ---> set this to OFF, it is ON by default.
See page 67 of the manual, you can also change conversion parameters if you want to leave it on.
