Originally Posted by aaltmann
My main issues are:
- When watching some SAT TV on a HD channel and I use AutoSurround,ACL or Digital, I can barely hear voice or not at all but can hear the music soundtrack and other effects (people walking, door closing etc.). It works with Stereo.
- When watching other HD channels, I can get voice if I crank it but it there is a lot of bass and the commercials are too loud.
- Some commercials work, some don't on the same channel.
- Sometimes when I change channels and a commercial is on, I get no sound unless I toggle the input.
I've tuned off KURO Link.
Check that Dolby Digital is turned on in the Directv box
Set the speakers to Large with SB No as suggested by polk.
My main issues are:
Sounds like an issue with the soundbar, what speaker outputs are you using? Does the soundbar have a center channel input? Does it have a separate subwoofer input?
I'd say the soundbar plus AVR combination is not ideal, the AVR is designed to drive a 5.1 or 7.1 separate speaker system.
As for DirecTV, read back a few pages, you need to connect it via optical as the audio over HDMI doesn't work right in combination with the 1019.
