AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Pioneer VSX-1019AH Owner's Thread
The "Official" Pioneer VSX-1019AH Owner's Thread - Page 11
post #301 of 5086
Originally Posted by CruelInventions View Post
if you go to the walmart website, you'll find it listed there as available online only, not available in stores. furthermore, the price is still listed @$398, however, it's out of stock at this time.
i don't know what's going on, but i only see the 800 series for about $299 or so. can you send me a direct link to the 1019? i've looked three times and still can't find it on their site
post #302 of 5086
Originally Posted by gpjnevada View Post
If you don't need the up-scaler or extra HDMI port, the 919 can be had for $349 shipped from J&R, an autorized Pioneer seller. If you take advantage of 5% Bing cashback, it's $331 shipped. Dang good deal IMO.
if i'm spending as much as i am on my setup now, i'd rather go ahead and get the up-convert and extra hdmi for another $70 or so. just personal preference. thanks for the heads up on that, tho!
post #303 of 5086
Originally Posted by Walkerbrown View Post
Hello 1019 and 919 owners, just wanted to ask you guys an issue on picture quality.
I own an Panasonic bd-35 blu-ray player, Pioneer 5020 plasma, and have purchased an 819h Pioneer receiver.
I am having issues with the picture quality 1080p 24fps through the receiver via HDMI connections. The picture was fantastic without the receiver but when the receiver is connected the picture is duller, less sharp and a slight judder with movement, pans etc.
I have tried two 819's with the same problems. I am not looking for a upscaler just a great pass through of the original signal. Would the 919h or 1019h elimate my problems with picture quality? Have you made a comparison in picture quality, with and without the receiver, and is it worth me upgrading?
I have the VSX-919, and the picture quality on my 50" KURO is fantastic. It looks identical with or without the receiver.
You are not the only one with issues with the 819 image quality. I would recommend upgrading to the 919. Someone listed a very good price from J&R above this post, and they are an authorized dealer...
post #304 of 5086
At Wally World
post #305 of 5086
Originally Posted by JChin View Post
At Wally World
thanks. i guess it wasn't showing up since it's out of stock
post #306 of 5086
Originally Posted by ecutchins View Post
There is a Toslink connection on the old Xbox. It is on the AV plug. I have an old Xbox connected via Component and Toslink and I get 5.1 out of the Xbox. I really brings games to life.
I got that all figured out last night. I can't beleive that I didn't even notice that there was an optical plug in the Xbox HD Cables. Go figure.
post #307 of 5086
I wouldn't buy any AVR that weighs less than twenty pounds if it cost about $400. Thats twenty bucks a pound , not a good deal in my book..
post #308 of 5086
Originally Posted by jayinla
One quick question, when receiving PCM from the PS3, the 1019 does and should say "PCM". Is there anyway to change the display to at least maybe showing the input rather then the code?
Originally Posted by tex94 View Post
Sadly, no.
I have seen this a few times and my receiver was always showing PCM....until last night!
I have had a 5.1 system for many years, after getting on this forum I decided to go 7.1. Last night I hooked up the extra two speakers and reran MCACC. Now all of my blu ray movies display ---
{Dolby Digital symbol}+ Pro Logic IIx Movie
I rechecked that the audio was on AUTO Surround. What gives? I didnt change my PS3 settings at all. Is this good or not? Should it say PCM like it did before?
post #309 of 5086
It just means that it is using PLIIx to convert your PCM signals to 7.1 sound. If you selected 'direct' you would still show PCM.
post #310 of 5086
Wow, thanks for the fast response.....again
Which one do I choose? Which sounds better?
post #311 of 5086
i don't even have the receiver (altho probably buying soon) and managed to spend 10 minutes reading the 10 pages that go with this thread.
to the poster who said he got his receiver at a WM: which part of the country are you in? $398 is a great price right now. I'm assuming it was a B&M store and not online?
It was Online, I went to get the link today and I could not find it, I look in the browser history and when I found the page it is "Out of Stock".
"/catalog/product.do?product_id=11064253"
Tampa, Florida.
post #312 of 5086
That is for you to decide. Personally, I prefer Neo:6 for music oriented programs (including movies with a lot of soundtrack) and PLII for more dialogue based programs. For me, PLII just seems to do a better job with the center channel and Neo:6 does a better job with L/R and surrounds. It's all personal taste though so I'd just play around to find what makes you happy.
post #313 of 5086
Thanks for your responses, great help guys. Looks like I may be upgrading to the 919h.
post #314 of 5086
Ok, I will try that but do I choose direct? Auto Surround? or manually choose the PLII or NEO6?
post #315 of 5086
Whichever sounds best to you. Here's what happens under each scenario:
Direct: takes whatever you feed it (PCM, TrueHD, 2 CH Stereo, etc.) and spits out that exact feed with any adjustments you have in the AVR (i.e., bass management, EQ, etc.).
Pure Direct: essentially the same as above but this turns off all of the AVR adjustments. This is the purest representation of source material but it may or may not sound good (which is why we have all of those 'tweaking' options and MCACC and other features).
Auto/Standard Surround: this can apply a surround mode for your set up. If you have a 7.1 setup and feed a 5.1 PCM source it can apply an algorithm to take those 5.1 channels and create 2 new surround back channels. Different algorithms (PLIIx, Neo:6, Neural THX) will produce different sound quality but all do essentially the same thing. None is inherently 'better' it totally depends upon your personal taste.
post #316 of 5086
I have been looking at the 1019 on several online retailers and have noticed that several of them have added $50.00 to the list price on Pioneer's web site and then marked it down to slightly below Pioneer's list. They are then advertising that you are saving over $50.00. One site shows the correct list price then tells you to add it to your cart for the sale price which is $.06 less. Isn't it illegal or at least unethical to lie about the list price? Why doesn't Pioneer do something these dealers are misrepresenting their products? These are dealers from Pioneer's list of legit dealers. This pricing is on all of the new AVRs.
Tom
post #317 of 5086
I just setup my 1019 and Pioneer Plasma (111-FD) thru HDMI. Also connected my DVR, Dish VIP-622 thru HDMI. I notice though that when I turn ON my system and tuning to an HD chanell, everything is fine. But when I change channel to a non-HD channel, no sound is coming out of the receiver. Either I have to turn off the receiver or the TV.
I turned off the Kuro link but it didn't help. Anyone had this issue? Thanks.
post #318 of 5086
When you turn off the receiver or TV and turn them back on, does the audio for the SD channel come back? If so, that sounds like an HDMI handshake issue.
Does your DVR support an optical output? You might try that, and use signal select on the receiver to select the optical input (DIGITAL?). That might work.
post #319 of 5086
Hi all, new here...great forum!!
I just found this unit online for $386.45 with free shipping at Ibuydigital.com. Here's the URL, http ://www.ibuydigital.com/product/?55543&camp_id=209 (being new, I can't post URLs until after my 3rd post so please remove the space after http).
I don't know anything about this retailer, so buyer beware.
I have a question regarding the HDMI handshake issue. Could the problem also be a HDMI revision issue. I'm assuming the 1019 is equipped with HDMI rev 1.3, correct? Is it possible that the component you are trying to connect to the receiver is of an older HDMI rev? According to wikipedia (I know, not the greatest source), "Consumer Electronic Control (CEC) has been in the HDMI specification since version 1.0 but only began to be used in CE products with HDMI version 1.3a." So, is it possible some "older" components may not be compatible to CEC?
post #320 of 5086
It's not showing up anymore if you search for it.
post #321 of 5086
rvfav
I've heard of this from someone on the Directv forum and they switched HDMI cables and the problem went away. I have the same problem but haven't switched HDMI cables yet, but if I switch to another input on the 1019 and then switch back the sound is there. If I'm tuned to a non-HD channel when I turn everything off the next time I turn everything on again and switch to an HD channel the sound won't be there. So I'm pretty sure it's an HDMI handshake that might be solved changing to a 1.3a HDMI cable.
post #322 of 5086
that's correct. when i turn the TV or the receiver off/on, the sound from SD channels can be heard. is there a way to work around this without using the optical cable for sound, it just defeats the purpose of using hdmi for simplicity.
i thought there's a setting I can do on the receiver to make this work. i'm not sure if changing the hdmi cables will help but i only have those eforcity hdmi cables from amazon ($1+) but had no problems connecting the DVR direct to the TV before. how does one know if the cable is 1.3 or 1.3a compliant? Also the Echostar DVR (VIP-622) from Dish I believe is not 1.3a compliant (supporting HD audio or Deepcolor). I guess it's more of an incompatibility and perhaps the VIP-622 needs to be upgraded.
http://www.audioholics.com/education...g-hdmi-ver-1.3
post #323 of 5086
Hey Everyone,
Long time reader here. I just picked up this receiver and only have 2 speakers. What's the best way to connect them? I ask because I have my Sony LCD plugged in via HDMI and it sounds like the volume fluctuates a little especially on commercials. Is there some setting I need to change to keep the volume constant?
Chris
post #324 of 5086
Sorry, forgot to mention, my video source (also connected via HDMI) is a Comcast (Motorola) DCH 3416
post #325 of 5086
Hi everyone, first off let me say i'm brand new to audio equiptment so bear with me.
My question is about a VSX-819h. Im not sure if the 1019 has this feature or not but i hope someone can help.
When i select the STANDARD button for the surround sound, everything seems to work fine, however when i select anyone of the ADV SURR button options (advanced surround effects, for action, drama, advanced game etc...) , all the speakers seem to work at the same time and the sound has an echo effect to it, similar to being in a barrel.
I've tried everthing i can think of and nothing has worked, not sure if im doing something wrong or maybe its defective, hopefully someone has an idea.
thanks for the help, M
post #326 of 5086
Troll much?
Believe it or not, some companies are capable of producing excellent products in small packages, just like Pioneer has done with these receivers. I'll bet you can think of more than a few great products in small packages
That may sound like what a troll may say to a newbe. But some of the new crop of AVRs in the $400 range have losted a few pounds Pioneer 1018 to 1019 , and the yamaha 663 to 665 , just to name a few . Onkyo and denon are still in their same weigth class. What does that all mean, the amp section still has balls basicly and music will sound clear . The marketing people use high THD levels about ten times more THD to keep the wattage figures level with units in the price range , but this is an old trick from the 70's.. Please don't hate me cause I pointed this out !! Overall the pioneer may work for you, but for about the same money you could get better ..
post #327 of 5086
In case you missed the link a few pages back, here's a review from CNET:
http://reviews.cnet.com/av-receivers...?tag=mncol;lst
Specifically note the first paragraph under Audio Performance, "The VSX-1019AH's sounds better than any $500 receiver we can think of. Looking over our notes for last year's Pioneer VSX-1018AH review, the two are similar, but the new receiver sounds like it has more guts and oomph, despite the fact that it weighs almost 10 pounds less."
Technology these days is amazing
post #328 of 5086
Yes in deed, this did get very high marks from the reveiwer. For video they pick to compare to the onkyo 607 which only does 1080i and for audio they pick on the yamaha 665 (HA Ha ha ). To say they picked there battles wisely would be a understatement for sure . But overall at less than $400 with some really nice features , usb, gui . It looks like a winner, If only had pre-outs and ac outlets..
The world wide score card for AVRs in the low to mid price range clearly now puts yamaha on the bottom !!!!!
post #329 of 5086
Got a question regarding the iPod cable that comes with the 1019.
I believe the 1/8" headphone jack on the iPod is amp'd, correct? Since the included iPod cable connects via the 30 pin connector on the bottom of the iPod would this be a pre-amp output?
Also, on a side note. I read some where that the 4th & 5th generation iPods utilizes a Wolfson DAC chip. Is this true?
EDIT: Never mind regarding the Wolfson DAC question. I just found some sources online that validates this claim. Thanks anyway.
post #330 of 5086
toomuchtv,
The key question is how often will the extra amp oomph! matter for the majority of owners? I would contend that most of the time, it won't. It's a non-issue for most.
Now, if you've got difficult speakers to drive, play them very loud in a larger room, by all means, amp power w/lower distortion should be an elevated concern and a key purchasing consideration. But a blanket statement along the lines of "the amp section is gutted therefore you should avoid", is not very good advice either, especially if a potential user doesn't require a ton of amp power and there are new features that might have real usefulness to them in the so-called "gutted" lighter, new receiver.
In the case of the vsx-1019, better ipod/iphone versatility and user-friendliness, multi-channel ALC control, among a couple other new upgrades. Now, if none of those matter to a person AND they want to play it safe and have a more powerful amp 'just in case', by all means, a previous generation pioneer, yamaha, etc., might be warranted.
In other words, sweeping generalizations are not helpful. It could scare off someone for whom this receiver might be the best choice.
