Originally Posted by Tintaffiny
First post and lots of questions, so I apologize ahead of time. Just got all brand new equipment for my home theater (after 8 years of nothing new). I "think" I really like my pioneer VSX919 but have some questions.
My equipment
Sony Blu-Ray BDP-S350
Samsung DVD player
Pioneer VSX-919 AH (receiver)
Panasonic TC-P50C1 (50 inch plasma vierra)
My set up is pretty simple. HDMI from Blu-ray to receiver, and HDMI from receiver to TV. DVD is set up by optical audio to receiver and component for video to receiver.
Questions
1 - How do I know what audio is being input to the receiver from the Blu-Ray disc (or DVD even)?
2 - How do I know what audio is being output from the receiver (given the above). Do these things show on the screen?
3 - I have "issues" with the receiver turning itself off once I turn on the Sony blu-ray player. Also, when I turn off the TV, the receiver turns off? Why?
4 - Why, in my ignorance, is the volume showing negative dB values....and then it can go to 12dB?
5 - What is Kuro Link and it's purpose?
6 - What is this "handshaking" with HDMI that you are all talking about? I don't see mention of handshaking in the manual anywhere.
My equipment
Samsung DVD player
Questions
As to:
1. - The Audio is identified on the AVR screen (stereo, TrueHd, Digital...) that tells you the kind of sound decoding happening in the 919.
2. - The receiveer always outputs to the speakers, so there is no need to note that.
3. - This I think is due to an HDMI feature called HDMI CEC, which lets you send control signals from one component to another through HDMI cables, like "turn on" or "turn off". The problem is that this is implemented in different ways and can interfere if you don't have components from the same manufacturer. In the case of Pioneer, this feature is called "KURO link", in the Sonys it is called "Bravia Sync". My advice is to turn both off, hopefully that stops the turn on / turn off.
4. - I think someone mentioned this earlier, but it is metered to reflect the volume at a movie theater (0), so in a home you go negative. But your guess is as good as mine if that's not so.
5. - KURO link is Pioneer's implementation of HDMI CEC. I have it shut off.
6. - HDMI is a software protocol that runs on top of the actual physical connection. Once you plug a cable in, and it realizes you have power, an interface on one component (let's say the 919) talks to the component at the other end (let's say your TV) and has a back and forth dialogue with it, sharing information with it and finding out the best way to communicate with it. If both ends of the connection are satisfied after this conversation, data starts to flow and you see picture and sound. If for some reason, one side is not happy (or both), the handshake has failed and you see things like blue screens on the TV or error messages on the 919.
