AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Pioneer VSX-1019AH Owner's Thread
The "Official" Pioneer VSX-1019AH Owner's Thread - Page 162
post #4831 of 5086
Hi Everyone, i would greatly appreciate any help on this.
I own a Pioneer VSX1019 AH-K. I'm trying to set up 5.1 with 3 Polk inwall RCi80 speakers for front, center & right and 2 polk inwall RCi60 for my rare. After making all my connections when i try to run sur-round sound my Pioneer shuts down. I've tested each speaker by using just the frontal connections and they work fine. I tried to RUN MCACC too and after initializing it shuts down.
What am i doing wrong? I appreciate any help i could get.
post #4832 of 5086
you almost certainly have a shorted speaker wire...
post #4833 of 5086
If the speakers wires were shorted. How could they have worked individually. I'm really confused here.
post #4834 of 5086
a) you didn't do them all individually, you only used the fron connections...
b) stuff moves around when music is played... doesn't take much to short... people sometimes experience the short only when something goes boom, for example...
many many people post here with your issue... 99% of the time, it's a short, even if they are "sure" they don't have one...
post #4835 of 5086
Hi all, I don't know how active this thread is anymore, but here goes, I have had this receiver now for almost 2 years and it has by far surpassed my expectations. My issue is this and I looked around the thread for an answer and could not find one. I just upgraded my xbox360(fat) to an x360 slim, when i turn on the xbox i get sound but no picture, im assuming it has something to with the auto-detecting the video, but im not sure. I have tried 4 or 5 different hdmi cables and no luck, the xbox works just fine when I plug it directly into the tv or into the tv in my bedroom, but I would really prefer to have it hooked into my receiver for continuity in my home theater setup, anyone have any ideas? thanks
post #4836 of 5086
Hello:
I have a 1019 updated with 1.056 firmware. I've noticed that when the receiver is being fed anything above DTS or DD 5.1, (DTS-HD, etc) the sound is mostly distortion. If I switch back to regular DTS of DD 5.1, there are no audio problems at all.
I've tried different HDMI cables and 2 Blu Ray players, same results every time.
Any suggestions would be greatly appreciated!
post #4837 of 5086
Have you tried switching inputs on the receiver? I know you said you tried 2 diff bd players so you likely used the bd input. Worth a shot. Try using one of the other hdmi inputs.
post #4838 of 5086
Just a quick question: when I send an analog stereo signal to the receiver set to Direct, it displays "96kHz Stereo" on the front. With Pure Direct, it displays "Analog Direct". Why would there be a sample rate displayed for an analog signal? Do I have to listen in Pure Direct (and lose any MCACC settings, as well as my subwoofer!) to hear a pure analog signal?
I called Pioneer, and the guy (confusingly) told me that it was displaying what it is capable of. Huh? He insisted he understood my question, and that I was hearing an analog signal, but I'm not so convinced. Am I wrong in thinking that 96kHz Stereo implies it has been digitized at some point, or is this just an oversight in their design?
post #4839 of 5086
I have also tried the other hdmi inputs, no luck. I'm "fixing" the issue with a new 1021 that I purchased for a killer price. I'll just move the 1019 to my gaming rig.
I called a repair shop and they want $50 just to diagnose the problem, then parts and labor for the actual repair. For the first time, I regret declining the extended warranty!
post #4840 of 5086
I have a question. I know this receiver does all kinds of things...but not sure of all the things. the question is if I have a movie that is in 5.1 what do i so it goes into 7.1
post #4841 of 5086
Hi All,
I'm relatively new to AV stuff.
I'm fluent in a Kenwood KA-A5020(look that sucker up kids), which is what I'm coming from. I'm a poor college kid, don't judge.
So I got this Pioneer 1019 from my Dad just recently(hand-me-down), this thing is pretty awesome compared to my antique.
Here is what I have: Samsung 8000(3D) - Samsung 3D BluRay player - Pioneer 1019. All in a 2.1 configuration.
Here is my issue: I have no sound coming from my sub woofer, AT ALL, while playing a DVD or Pandora or anything.
3D BD ---> HDMI ----> TV
3D BD ---> Optical ---> Receiver
This is the only good way to do things that I know of.
The TV is on HDMI2(3D BD player).
The Receiver on DVR(which is what Optical port 1 is labeled.)
If I wire it like: 3D BD ----> Receiver ----> TV, it sounds great, but a severe lack of 3D(obviously).
The OSD menu is very weird, and I'm positive the setting I need to adjust is in the crazy menu.
ANY POINTERS?!
Any help is much appreciated.
-PhatAJ
p.s. I tried getting a HDMI splitter, things only got worse and more complicated.
post #4842 of 5086
AJ-in the 1019 menu are the speakers set to small or large?
post #4843 of 5086
Currently set to large.
But, if I go directly from the BD player to the Receiver, the sound is perfect.
post #4844 of 5086
I've had this receiver for about two years, and I've been pretty happy with it. I got it for a steal at BB. Anyway, this has been bothering the crap out of me since I bought it and I haven't found any solution. When I change channels on my cable box sometimes the audio drops out and will not come back. If I switch to another input and switch back to my cable box input it is fine. I am using HDMI 1 + Digital Optical 1 for my cable box on the TV/Sat input.
post #4845 of 5086
Try setting them to SMALL and listen for the sub.
post #4846 of 5086
Make sure that you are using the sigsel to switch from auto to digital, otherwise the sound will still be input to the avr through the hdmi (which is why your getting drop outs). Happy Holidays!
EuroVW89,
i believe you can matrix sound to the surround rear channels (similar to matrixing 5.1 from a stereo signal) by choosing one of the matrix options (i.e., Dolby Pro Logic IIx Movie). See pg. 115 of user manual.
post #4847 of 5086
I will give that a shot... Hopefully that works. It gets irritating having to switch inputs and go back to TV/Sat when the audio drops out. Thanks!
Update:
It appears to have worked. Haven't watched much TV from the cable box, but it isn't dropping out and staying out when I switch between the channels where it had been a problem before.
post #4848 of 5086
Glad you got it working. Cable boxs are notorious for audio drop out when connected via hdmi (shrug).
post #4849 of 5086
I still get an occasional drop out, but not anywhere near as much as it had been happening before. Before it would happen nearly every time I switched between HD and SD channels or between HD network channels and HD "cable" channels. Now it seems to just be random. I'd guess it's just the shoddy cable box from the local telco.
post #4850 of 5086
Well the sub works now... But missing a lot of sound.. No mids, my bookshelf speakers have a 8" speaker in them. With my last receiver they sounded great. Not anymore. This damn osd is very complicated.
It has to be something in one of the settings to get my sub and my 8" woofer(on my book shelf speakers) working together.
Please help.
AJ
post #4851 of 5086
Hey all
I've been putting up with this for a while but it's doing my head in so I'm trying to sort it once and forever.
I have got my blu ray linked only by optical cable as it doesnt work with 3d movies when running the hdmi through the amp.
When I pause a DVD or rewind etc the source switches back to tv/satellite, it's really annoying and I have to keep switching back to dvr?
Anyone know how to disable this?
Thanks in advance
Gary
Oh and happy new year all
post #4852 of 5086
Originally Posted by Gazzerb View Post
Hey all
Thanks in advance
Gary
Hi Gazzerb, on the receiver try turning off Kuro Link (HDMI Control).
post #4853 of 5086
Thanks for the reply I'll try that. I'll look into the manual now
post #4854 of 5086
Should find this by going into System Setup -> Other Setup -> Kuro Link Setup
post #4855 of 5086
Well it only bloody worked!
Thank you very much for the tip.
It's been bugging me since I've had it set up this way.
post #4856 of 5086
Hi everyone,
I just read through 11 pages of search results for "subwoofer" and couldn't find a direct fix for my current problem. My system used to work perfectly fine months and months ago. A while back I turned my subwoofer (The Speaker Company ASW-10) off (via the switch on the back) and it has been off since. Last night I decided to turn it back on and it worked fine for about 15-20 seconds then just stopped working. Keep in mind NO changes were made to any of the connections since it had last worked perfectly fine.
I tried resetting the receivers settings and reran the MCACC and when it got to the sub I got a tiny, tiny little noise but then the receiver gave the message that volume on the sub is too low and to turn it up. Of course I had already tried turning up the volume and adjusting the crossover knob with no success. The most I have been able to get out of the sub is to put my hand on the actual woofer underneath and feel a very slight vibration with the volume turned up all the way (it could not be heard at all).
I tried turning the sub on and disconnecting the cable from the back of the receiver and touching the tip of to get a "boom" but it is dead silent. Does this mean there is something wrong with the cable or the subwoofer? Also, it was definitely plugged into the pre-out and not one of the multi-ins.
Is there a fuse in the sub that could be faulty? I really just want to get this working properly again, if anyone has any suggestions I would really, really appreciate it. If you need any further information from me please let me know. Thanks in advance.
post #4857 of 5086
Hi element192, if the power indicator lights up then most likely not the fuse. It appears either a sub cable or the sub itself. Try another sub cable (a composite cable (yellow) can be used if sub cable is not available). Test the sub itself by connecting a CD or DVD or iPod player directly to sub. Then play song that contain low frequency by slowly turning up the volume.
post #4858 of 5086
Hi JChin, thank you so much for the reply. I just connected an old HDDVD player with a not so 'bassy' CD (it's the quickest one I could find) and connected the red and white on the HDDVD player to the red and white on the subwoofer. As I turned the volume up there was definitely sound coming out. Although, turning the volume to the max definitely wasn't very loud at all. Not sure if this is normal or the fact that it wasn't bass heavy music... Is this a good sign?
As a side note, the higher I turned the frequency knob, the louder the sound got.
Thanks again for getting back to me.
post #4859 of 5086
I also just noticed that if I plugged the red cable into the left subwoofer input and touched the other end (that would plug into the receiver) I got a faint noise from the subwoofer. However, when I plugged the red into the receiver preout I still didn't get any sound from the subwoofer. It was the exact same as with the original cable. I even just did the MCACC again and got the exact same "low volume" result from my subwoofer. It still did make a very faint noise, I'm so confused over this issue.
post #4860 of 5086
Anyone else have any ideas? Why am I getting some noise out of it at times but not getting proper performance? Based on what I have written does it sound more likely that it's the sub, the cable, or the receiver? I really just want to get the system working and fully operational again, I forgot how much I missed using my sub... I would really appreciate more advice! Thanks.
