Originally Posted by
Ladic
Guys something happend on my receiver and I can longer get HD sound for my blurays out of it.
Anyone knows what is the confirguration procedure?
Not knowing what is actually happening or what your source is and how it is connected, I will offer up a few items.
1.Make sure that you are receiving the signal as digital (assuming its via HDMI from your Blu-ray player) and not analog.
2.Do you have the auto surround/ALC/Stream Direct button selected on the front of the receiver and not the others? (you should then get a blue light)
3.Is this happening on ALL Blu-rays from the player? If so, check if the Blu-ray player audio is set to Bitstream or refer to that players manual to get the digital stream from the player to your receiver, again assuming its via HDMI.
4. Or check that you are not selecting Stereo or 2 Channel output on your Blu-ray player rather than the HD formats.
Here are some other items from the manual.
Playing a source with HDMI connection
• Use INPUT SELECT to select the HDMI input you’ve connected to (for example, HDMI 1). You can also perform the same operation by using the INPUT SELECTOR dial on the front panel or by pressing HDMI on the remote control repeatedly.
No sound from the surround or center speakers.
• Check that the Stereo listening mode or the Front Stage Surround Advance mode isn’t selected; select one of the surround listening modes (see Listening in surround sound on page 53). • Check that the surround/center speakers are not set to NO (see Speaker Setting on page 95). • Check the channel level settings (see Channel Level on page 96). • Check the speaker connections (see Connecting the speakers on page 18).
Sound is produced from analog components, but not from digital ones (DVD, LD, CD-ROM, etc.).
• Check that the input signal type is set to DIGITAL (see Choosing the input signal on page 58). • Make sure that the digital input is assigned correctly for the input jack the component is connected to (see The Input Setup menu on page 39). • Check the digital output settings on the source component. • If the source component has a digital volume control, make sure this is not turned down. • Make sure that the multichannel analog inputs are not selected. Select any other input function.
