AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG "XXLH90" 240hz LED Owners Forum [NO PRICE TALK]
Official LG "XXLH90" 240hz LED Owners Forum [NO PRICE TALK] - Page 154
post #4591 of 4719
Originally Posted by seatownfunk View Post
Ya I would say so the LH90 is top notch!
It appears the later builds of the 55LH90 had better colour than the earlier builds. Upping the FW to Version to 3.13 will improve colour. May cause audio problems depending on how you playback your audio. Supposedly clears up the lip sync problem.
post #4592 of 4719
Did some searchs and read through quite a few, but can't seem to find my answer.
When I have no video coming to the TV, I can make changes to the video settings like turning TruMotion on High/Low/Off, then the settings changed to "Setting (user)". Once I connect video, it resets, and the TruMotion is greyed out. It's set to OFF all the time. Sometimes I want it on, but just can't seem to figure out how.
Sorry if this is a repost and already answered, my searches did not yield anything good answers. Thanks, all.
Enjoying the TV, but this little thing annoys me.
-Lacking TruMotion control-
post #4593 of 4719
WTF? What are you basing this opinion on?? Is this based on color accuracy? Explain
post #4594 of 4719
Never mind, I downloaded the manual and it indicates that TruMotion is OFF for "PC" input, so I just changed the input label to something else and it works fine. RTFM if all else fails.
post #4595 of 4719
Several Forum Members who did the FW update, all reported the same results - Deeper colour. Before the Update, couldn't remove the Milky Blacks I was getting no matter what tweaks I did! After, Milky Blacks gone!
post #4596 of 4719
Yep did firmware update myself to 3.13.1 and better color, big difference. Not sure why but I can tell the difference!
post #4597 of 4719
Don't know if you noticed it, but we now appear to have better off angle, and to a greater degree, PQ retention!
post #4598 of 4719
Did you do the firmware upgrade yourself or have a tech do it?
post #4599 of 4719
Did it myself. This FW applies to previous versions prior to 3.13.1. Requires a Service Remote to do.
post #4600 of 4719
You can do the upgrade without the service remote via the secret code as well
post #4601 of 4719
Hey guys,
Newbie here on AVS Forum, just now clued into this master thread on the LH90 series. I had posted a separate thread earlier, but this forum seems more appropriate for my question:
I bought my parents a Polk soundbar to hook up to their LG 47LH90 via optical out. After turning off the speakers on the TV, we have no audio on the HD channels. I think it's because the TV output is Dolby Digital for those, while PCM for the SD and non-HD cable channels. Is there any way to force PCM-output only, rather than Dolby Digital or any other mode, via the optical-out?
Appreciate any help!
post #4602 of 4719
I have LG 55LH90 + Denon AVR-1911 + PS3 Slim + Comcast cable box and just wondering if anyone has the same set up. I do not believe the cable box matters to much, just wondering what settings you have for each component for things to work together smoothly. I have the PS3 and cable box connected to Denon AVR-1911 with HDMI and HDMI from AVR to TV. I have not had time to read each thread dedicated to each component and all the components are fairly new( 3 months old max). Please share connections, settings and what remote control would be adequate to operate all components and their features. Thanks!!!
post #4603 of 4719
I have the original 60g PS3, 1911, 47lh90 and Motorola cable box...
Cable box--->1911 via hdmi
PS3--->LG via hdmi
PS3-->1911 via optical (you must tell the PS3 to use this in audio settings)
I did it this way because I notice a good bit of input lag during FPS when running the PS3 through the 1911. If you don't game much, then running the PS3-->1911 via hdmi will suit you just fine. IIRC you would also want to run the PS3 into the 1911 if you have a 7.1 system to get the full effect...mine is only 5.1.
The 1911 remote will control on/off, input switching and menu items on the LG. You use the bottom left buttons (they have red on them iirc) on the 1911 remote for power and inputs. To get into the LGs menus, you must first hit "tv" (you will get a blank screen) then menu on the remote.
It will not run the cable box (at least it didn't run mine)...iirc there was only one code for the Motorola, check it and see, you may have a Scientific Atlantic or something. Good luck!
post #4604 of 4719
My components are similar to yours:
LG55LH90+Denon AVR 790+ HTPC+Roku XD> All connected via HDMI to AVR>HDMI to LGTV. I do turn off scaling on the AVR.
Do yourself a favor, purchase a Harmony Remote. It will control all your devices perfectly. WAF will be very high.
post #4605 of 4719
Which Harmony do you have JDP?
I found fps laggy even with the scaling off. I like the scaling for the cablebox though...I don't use the "wide" setting though, it stretches the image too much.
post #4606 of 4719
I have an older one Harmony 670. Works great for my needs.And so simple to use, even my 2-year old figure it out.
You may need to purchase an additional adapter to control your PS3.
I hear people rave over the Harmony One.
http://www.amazon.com/Logitech-Harmo...4340411&sr=8-1
http://www.amazon.com/Logitech-Harmo...4340411&sr=8-3
post #4607 of 4719
Cool, ty!
post #4608 of 4719
Thanks for the reply guys. I'm not a serious gamer so lag is not that noticeable or important, yet?!? I like the all HDMI setup now, if i get to that point i will sure remember your solution. Great help.
post #4609 of 4719
Racking brain here trying to figure out what "fps" stands for. Frames Per Second or something else.
post #4610 of 4719
Sorry, first person shooters. Games like Call of Duty, Fallout, etc. You will also notice lag on games like Street Fighter, Mortal Kombat, etc.
post #4611 of 4719
hof - FPS= First Person Shooter like call of duty black ops
post #4612 of 4719
No I am sorry. I'm 40 and trying to get back in to the "know" of technology and it is alot to learn. I lean more to sports and racing games, back in the day there were not much fsp's. I did love Mortal Kombat.
post #4613 of 4719
You won't notice it much on racing games...here's what you are looking for though if you want to test it out to see how sensitive you are to it. When you move the joystick to the left or the right in a fast motion, do you notice it doesn't respond on the screen as fast? If the answer is yes, try plugging the PS3 directly into the tv and see if it changes for you...it's real bad on the Wii, but the Wii works all on motion. You will also want to turn local dimming off (or just go to game mode) for games...the more processing the tv does the more input lag you will have.
Of course, some people (and games) are more sensitive to this than others, all depends on you. Check out Mortal Kombat vs DC Universe...pretty decent!
post #4614 of 4719
Link to ChadB ISF calibration results
http://www.avsforum.com/avs-vb/showt...2#post18317902
post #4615 of 4719
I second ChadB!!! $$$ well spent IMO!
post #4616 of 4719
Just had to put this in, there's been no input for a while!
Chroma5 Standard coming in shortly. Will see if it has more control over the 55LH90 than my Enhanced Version. Will also try out the ChromaPure new version as well at the same time. (Not available yet - watch for it!)
post #4617 of 4719
Where do you get the 3.13 firmware upgrade?
post #4618 of 4719
FW Updates come from your Local LG support techie - note, you will have to try and convince him you have a lip sync problem. Updated under warranty. Out of warranty, require Service Remote. File is 21.6 Meg
SERVICE BULLETIN
Page 1 of
5
Factory
ENRS
ENRS
ENRS
Factory
Suffix
Factory
Model
42LH90-UB AUSVLHR
47LH90-UB AUSVLHR
55LH90-UB AUSVLHR
Sales
Subsidiary
ENAI
AUSVLHR
AUSVLHR
Sales
Model
42LH90
47LH90
55LH90
Sales
Suffix
AUS
AUS
AUS
Customer
Model
42LH90-UB
47LH90-UB
55LH90-UB
Factory
ENRS
ENRS
ENRS
Factory
Suffix
Factory
Model
42LH90-UB AUSVLJR
47LH90-UB AUSVLJR
55LH90-UB AUSVLJR
Sales
Subsidiary
ENAI
ENAI
ENAI
Sales
Model
42LH90-UB
47LH90-UB
55LH90-UB
Sales
Suffix
AUS
AUS
AUS
Customer
Model
42LH90-UC
42LH90-UC
42LH90-UC
Buyer
Buyer Name
LGEUS
Buyer Code
US000001
Buyer Name
LGEAI
Buyer Code
US000002
Buyer Name
Buyer Code
EFFECTIVE
DATE
Subject
EFFECTIVE FROM (SERIAL NO.) All
No. Loc. No.
Part No. DESC./SPEC.
Before Change
After Change
Note K-Code Remark
[S/W Update] Improve Lip sync problem (LH70/LH90)
2009-08-23
Symptom
Lip sync problem occurs when the following models are connected to a Set-Top-Box using HDMI cable.
Notice
1. This SVC bulletin includes the latest software download file. It can be applied for old issue as well.
2. You have to write the SVC bulletin number in the "Remark" or "Description" cell after repair.
3. Please apply this solution only to TV that has the same symptoms.
Applicable Model No. All models listed below.
Countermeasure
1) Please download the attached software files.
v) 32/37/42/47LH70-UC Please use the following file: (0.1.54.97_flash_VENUS_V32101_LH70US.epk)
vi) 42/47/55LH90-UBPlease use the following file: (0.1.54.97_flash_LED_V31301_LH90US.epk )
(report & downloading guide)
After downloading the two files, please read the upgrade procedure (Pages 2 through 5)
Date: 2009-08-27
No. : 0IVL20090670
** FILE THIS SERVICE BULLETIN WITH YOUR SERVICE MANUAL
post #4619 of 4719
could someone familiar with this thread point me in a direction please? I have a 47lh90 I purchased about 15 months ago and it has the lip synch problem. I have learned to work around it somewhat by switching back and forth from hdmi to component but I would love to get a firmware update that would correct the issue.
The previous post makes no sense to me, what do I need to do to get the firmware update and apply it?
thanks,
Breeze
post #4620 of 4719
thanks,
Breeze
15 months later, do you have an extended warantee?
