Hi - I've owned an LC-C6577UM for a couple of years and am now in a new home where I will be mounting it on a wall. I ordered the Sanus VMPL3 wall mount, and read that the Sharp requires 10mm bolts for installation. So I went to the local hardware store and bought sets of 10mm bolts in both 1.0mm and 1.25mm thread distance, but neither seem to work in the VESA mounting holes on the back of the TV. I'm prepared to order Sanus's M10Kit for TV's that require 10mm bolts. It appears to include 50mm length 10mm bolts and spacers, which I imagine would be helpful for creating a little more wire space in the back of the TV. But I'm baffled why standard 1.25mm thread bolts would not work.
Can anyone advise if the mounting holes use some other thread pitch than 1.00 or 1.25mm?
What mount did you use to wall mount your TV?
Any tips for this?
Any tips for this?
I set the input, I watch. Other than pushing pause on the DVR or the BR or the HD-DVD... I change nothing... sitting there on the couch and it up and changes the video setting - always to Dynamic.
