Originally Posted by garnuts
To change/try different listening modes use the 4 'Listening Mode' buttons on the remote. Each time you press the same button the AVR will cycle through all the available listening modes for the source material. Your available modes are dependent on whether the source is Mono, Stereo/2.0, 5.1, PCM.
PLII (Pro Logic II) expands a 5.1 source to 7.1 output. You would want the 'THX Cinema' mode (pg 73) for your 5.1 setup. Ultimately, after reading about the listening modes in the manual and experimenting with them, we each choose what sounds best to us.
I'm not sure why your 707 defaults to analog settings. The default audio settings are 'Last Valid' for each input, meaning which ever listening mode was last used for that input and source type (5.1, 2.0 etc), should stay the same if the 707 is turned off or inputs are changed. (This can be changed in the audio setup menu)
I spent a lot of time reading the manual and this thread, and experimenting. Once you understand the capabilities of the 707 and how it works, its a great AVR. Especially at the Black Friday price.
Thanks Garnuts! Do you recommend THX DTS Cinema or THX Cinema?
oh well
