Originally Posted by
EAS
Can you describe the 'degradation' a bit?
Sound is muddy. Loses definition, both treble and bass are lost and overall it becomes somewhat garbled sounding.
It's like listening to a cheap boombox or something.
By comparison, the CD Direct mode is quite clear-sounding, with clear bass and treble and more apparent power and full-bandwidth clarity. (It sounds like it should.)
EAS
Do you have a 5.1 speaker configuration or do you have 2.1?
3.1: Front L/R, Center, Sub.
EAS
Did you run Audyssey?
Audyssey will not run when 707 is bi-amped. (At least, not this one.) So I ran it first without bi-amping, then connected and configured bi-amping. The CD Stereo mode produces the same degraded output sound quality whether Audyssey was run first or not.
Interestingly, the CD Stereo mode is also slightly degraded sound quality (vs. CD Direct) when running normal Front L/R hookup (not bi-amped), but the degradation is much worse when bi-amped. This makes me suspect the processor, which appears to degrade the sound quality in CD Stereo mode in any case.
EAS
Are your fronts configured for full band?
No, Fronts and Center are configured for 80Hz crossover (THX default).
Of course, this is bypassed when running CD Direct mode, which only sends full output (no processing, no crossover) to Front L/R.
EAS
Have you changed any configurations for double bass?
Double-bass is not available if Fronts are not set to "Full Band". (Mine are set to 80Hz) I don't want Double-Bass; I want to divide the bass between SW and the other speakers, not double it.
