Originally Posted by
Sickneedhelp
Is it safe to come out of hiding now?
I suppose so. I'm just trying to implement a resonant mode converter 'model' to dangle on my amplifier 'model'.
Since the topic of capacitor life appears to be of interest to some, I'll put forth some capacitor basics for the non-engineers in this forum. For the engineers, this is remedial reading. I apologize for boring you with this.
Muh-Huh
1) Capacitor life expectancy is based on maximum rated temperature at maximum ripple current and maximum voltage. Any deviation from the above yields an increase in life expectancy.
Yup, voltage below surge or at rated might not be a major bigee. What you are after is the heating effect of RMS ripple currents and operating temperature.... plus as you mention, environment, plus 'cooling'.
2) Capacitor life hours do NOT indicate the capacitor will fail within the specified hours. The life hours reflect an expected time period where the electrical characteristics will still be within the industry's standard limits (in this case ~ 20%). The specific application will determine the amount of deterioration allowed before a significant impact on the end product's performance occurs.
Indeed! I think I hinted at that when I asked you for more 'specific' data on the capacitors, found some but probably not enough, being used but then you came up with something like nothing and are hand waving once again. Tell me, if a spec like ESR goes out by ~20%, and I will assume that is a rise, does not the dissipation for the same ripple current go up by ~20% and as a result accelerate the failure?
3) With a little help from Arrhenius' Law of Chemical Activity, we conclude that the life of a capacitor doubles for every 10 degree C reduction of core temperature. A cap rated for 2000 hours at 85C is rated for 64,000 hours at 35C. This equates to 7.3 years.
That one is a little bit simplistic. Now you are talking about 'core' temperatures whilst ignoring core to case, case to sleeve and sleeve to ambient thermal resistances. You should agree, but I'm sure you would wish to 'bluster' that a 10C reduction in surface temperature really does equate to a 10C reduction in core temperature, although it does not. If you have the data then you would see that the curves are a bit bendy and don't really work in favour of your 10C doubles things scenario.
If Nippon Chemi-Con are not giving you the full banana then try visiting,
http://www.epcos.com
or
http://www.vishay.com/company/brands/bccomponents/
For some seriously meaningful data. Eeeeeee, when I wer't Lad..
Otherwise, assuming you have them, you might be able to publish your own.......{?}
Sorry folks, I realise this might bore people in AVS but I get the impression that Mr Bennett would rather I kept my tirades in one place. Hopefully you have an ignore button.
4) Ripple current specifications are frequency dependent. The baseline is for 60Hz applications. For a high frequency switch mode supply, the ripple current capability increases to approximately 1.2.
Indeed. I assume you knew that already and are not just flossing from the, lack of, information I pointed you at? However you are dealing with
both the low frequency audio component
and the high frequency switching component. If you wish to operate at limits then you need to check that sort of thing..
5) Ripple current specifications are temperature dependent. The baseline is the capacitors max temperature rating in STATIC air. A cap rated at 85C typically has twice the capability at 35C.
Indeed. I assume you knew that already and are not just flossing from the, lack of, information I pointed you at, although the multiplier was stated at 45C?
Oh. Kudos to AVSBama on the question about my choice of 'representative' capacitor. It would seem, waffle waffle waffle, that the devices in question are actually Q50 case size, 25.4mm X 50mm. My Bad. I would not wish to bullpooh about that but I might get the impression that the Volume/SurfaceArea ratio works in their favour in terms of dissipating internally generated heat.
6) Voltage derating also increases the life of a capacitor but to a far lesser extent. Conversely, short term increases do not have a significant effect on life, provided the surge voltage is not exceeded.
Indeed! Ref the Epcos reference. It's a gentle curve to breakdown with a bit extra left to go. Mind you, it does look like that was the one you were bothered about whilst ignoring the other stuff. I'm sure everyone else does it as well.
Now let's apply this to some real world application chosen purely at random. Ummmm.... how about the IPR1600
Sounds GOOD to me!!
Way up there ^^^ early after my joining this forum, a certain buddy of mine who's name has come up a lot lately made a critique in this and other forums about the need to improve the air deflector of the IPR.
Oooooh that will be sarcasm and I'll say I only mentioned it once so you can find the other one and use it to totally destroy my reasoning.
The contention was that it could be improved by deflecting more air on the output power devices. Real world experience has taught us that while cooling the power devices is important, also cooling the rest of the components is equally important for overall longevity.
Works for me...
A look at the internal photos (readily available now) shows that the air deflector as currently designed partially envelopes the secondary supply capacitors. The purpose is obviously to air cool the capacitors and thereby keep the core temperature to below 35C. Please refer to item # 1 & 3 above.
Muh-Huh...
So this will be why the air deflector is positioned to cool something like the lower 80% of 20%, for a whole 16% effectiveness, of one side of one capacitor whilst the other one sees not a lot in terms of 'cooling' air. It will also explain why the, one, capacitor, being cooled receives its cooling air directly through one of the, exceptionally, close proximity output inductors.
Still, I assume that at your 'rated' output power levels those inductors don't get very warm at all. Not a problem then. Probably applies to the other capacitor receiving not a lot of airflow and its, not hot, inductor sitting next to it either.
In a conventional linear supply (meaning 50 & 60Hz transformer), the supply caps are the primary source of energy storage, recharged at 100 or 120 times per second. Any degradation of the capacitor performance can have an impact on overall amplifier performance. In an amplifier with a switch mode supply (IPR series), the capacitors referred to frequently lately, are secondary capacitors. They are recharged 210,000 times per second by the primary capacitors.
AHAAAAAAH, I See you have entered Pro-Audio Waffle Mode.
'Our power supply recharges stuff absolutely HUGE amounts per second for most excellent things and stuff like pumpy base and dynamics with throb when you need it.'
Yay!! We are believers. Gosh 210,000 times a second.
Again, way up there ^^^^ I made the point that the primary capacitors of the IPR are double that of comparable powered switch mode supply amplifiers. 210,000 recharge pulses are more than adequate to transfer energy from primary to secondary capacitors to sustain audio frequency demands. This means that the effect of degradation of secondary capacitance has minimal effect on performance. This assumes the secondary capacitors are properly bypassed with poly capacitors to negate source impedance related effects at switching frequencies (they are in the IPR).
Excuse me, sorry to get Techy, but resonant mode conversion slaps the capacitors at about 1.53 times the RMS of the load if you get it right and you are running up to 30 Amp 5uS half sine pulses based on rated power, I'm still looking to get proper figures for that one, into your secondary side main ponies and are expecting some 'poly' capacitors to save them from the onslaught?
Then you say
Works for me... not.
Do you wish to get into a conversation about 'de-coupling' capacitors and their impedance characteristics along with circuit trace and device inductance and resonances and...
That reminds me.
ArthurG. Next time try not to 'bad off' Eva
As the above paragraph relates to the real world, the 7.3 years in item # 3 above easily becomes 14.6 years, assuming the amplifier is operated at it's limits throughout the 14.6 years and, no significant degradation of performance is allowed. Real world tells us there are not too many venues where max demand occurs for 24 hours/day. There may be some clubs that operate at maximum level for perhaps eight hours per day. Now the life expectancy of the amplifier capacitors becomes >43.8 years before significant degradation of performance.
Nicely delayed. Obviously I can't 'prove' it yet but your rated figures take those capacitors down close to their 2000Hr Limit.
Item # 6 above, requires that protection circuitry exists to ensure that internal voltages are within safe (to the capacitor) limits. In the IPR, this circuitry does exist.
Well done. It seems you were truley focussed on that one. Design to the limits you understand or someone else has told you about, protect against them and miss the other important things.
I noted that a posted simulation assumes an incorrect amplifier switching frequency and an incorrect output inductor value. The former accounts for the incorrect bus pump voltage (as does the 10Hz signal applied) while the latter accounts for the incorrect damping factor spec tossed out in this forum and other forums.
The former will have little to no effect on the bus pump voltage and the signal frequency imposed is most exceptionally important. The latter is my guess at a value for your output inductor and its possible DCR. It would 'seem' that I was a whole factor of two out which isn't bad going for looking at published pictures.
[Regarding that one. Being someone who does not listen to monsters making lots of noise at low frequencies whilst they rip loads of guts out of their human, or other, victims and you are watching them doing it 'on screen' or even know what F3/FR might be I guess I might qualify as stupid and I am, almost, not really prepared to learn but if your sub is ported to suck power down low and your IPR cacks out then.....]
In summary, my hope is that after 44 years of severe demand, the customer has amortized his $299 investment.
So it's a door stop... but not heavy enough to do that either?
If I'm completely wrong about all of the above, a certain individual's computer power supply capacitors will fail within the alleged three months and this will all soon be over with.
That's all right. They sell millions of them and probably run HDBK-217 or the commercial equivalent on the designs whilst making sure that the F in MTBF is not a four letter word.
