AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Firmware Upgrade for PN42B450
post #1 of 4
I noticed on the samsung website there is a new firmware update (ver.1013) for the PN42B450. (I think my tv has version 1005.0).
This is my first HDTV so I'm a little hesitant to try it out. Have any of you PN42B450 owners out there tried this update? If it bricks my tv, is it covered under warranty? Anybody know what the update fixes?
post #2 of 4
I just did this F/W upgrade on my PN42B450 and everything is OK. I had the 1012 version, where as this one is the 1013. Enjoy your PDP!
post #3 of 4
Any idea on what is fixed or changed with the upgrade? I can't find anything on samsung's website
post #4 of 4
build date : 2009-04-16 firmware version 1013
* The firmware will correct the following phenomenons some units may experience.
- If customer turns unit off and back on,
. he loses his channels
. the TV displays ''Weak or no signal''
. the cable system''s setting always changes from ''HRC'' to ''STD'' though he set it to ''HRC'' before
- The problem happens at the region where the cable system is ''HRC'' or ''IRC''
Not enough there for me to risk updating. My set is working great.
