My question is..... which option is better IF the only HD recording you do is from a cable STB?
I have been doing QAM recording of non-premium channels, but have yet to buy a Hauppauge HD-PVR primarily because I have no interest in recording from any component sources other than a STB and my cable provider did not used to give us premium HD channels that I was interested in saving. But now that my cable provider has begun to broadcast some premium channels I like in HD, I am considering to get either a Haupauge HD-PVR or cable card tuner(s) on my Win 7 PC.
I have been interested in HD-PVR all along but with Win 7 RC Media Center having the ability to work with a cable card, would it be a better option?
The resulting recording will be in .WTV which is kinda pain, but Win 7 allows a right-click and convert to DVR-MS for mpeg2 stream WTV recordings (which is the case in the US). I'm not sure if that is applicable to encrypted TV channels though as I 'suspect' that one of the purposes of developing the WTV format was perhaps to protect broadcaster's copyright? If that is not the case though,,, companies that make popular video editting soft (e.g. Adobe, Pinnacle) may start making softs that take WTV for input in the future.
One downside of this is that for those who already own regular QAM tuners at this point, this method requires another tuner that takes cable cards. But you could argue that getting a tuner like that eliminates the need for a cable box and separate DVR. And in my particular case, I have to buy either HD-PVR or a cable card tuner anyway...
What are thoughts on a cable card tuner vs Hauppauge HD-PVR specifically for premium HD channel recording, editting and storing away permanently?
p.s. my PC spec, current tuners, cable setup
Core 2 Quad Q6600 2.4GHz, CORSAIR DOMINATOR 4GB (2 x 2GB) DDR2 1066 (PC2 8500), SAPPHIRE Radeon HD 4850, GIGABYTE GA-EP45-UD3P ATX, PC Power & Cooling S61EPS 610W, Western Digital Caviar Black 1TB HDDs in RAID 1, LG 22X SATA DVD Burner with LightScrib, Winodows 7 RC x64 & Vista Home Premium x64 Dual Boot, Antec 900 Case, Pinnacle PCTV Tuners and Hauppauge 2250 Dual Tuner, Time Warner Scientific Atlanta Explorer 8300HDC.
