AVS › AVS Forum › Audio › Speakers › polk or hsu
polk or hsu
post #1 of 13
hey there. I am trying to decide on the following speakers as small surrounds
1)polk 101- $60 each
2)polk 6751- $45 each
3) hsu vt-254 (from ventrilliqust package) - $50 each
post #2 of 13
any opinons on which of these low cost options would be best as surround satillites
post #3 of 13
I had the Ventriloquist package before I upgraded and have no qualms in recommending it. Very good speaker for the price. I am still using the sub that came with the package and see no need at present to upgrade it.
post #4 of 13
would that satillite be fine to use as surrounds in my system. Do they connect regularly into the receiver, i thought they went to the center channel first or something?
post #5 of 13
What are the rest of your speakers?
post #6 of 13
You are going to be putting about one watt of power into them. Dont get too crazy about something like this. Matching your surrounds to your mains is not a bad idea but its not really necessary.
post #7 of 13
if it matters, my mains are energy c-200
post #8 of 13
Then why not go with Energy surrounds?
post #9 of 13
These will be mounted to the ceiling. The room extends into the kitchen, energy makes no speaker this small, if they do it is cheap
post #10 of 13
In that case have you considered any in-ceiling speakers, like the Mirage Omnicans? I've never heard them but they're regarded as being an excellent in-ceiling model due to the enclosed design.
post #11 of 13
how much do they cost, i am not really into in-ceiling speakers as i am going to be moving in about a year and dont want to cut holes into the ceiling
post #12 of 13
yeah, i dont know i guess i am leaning towards the hsu speaker.
post #13 of 13
the only minus i can think of towards the hsu is that it doesnt look as good as the polk RM101.
I have no idea about the sound though. Keep in mind that the choosen speaker will be used as the height speakers in a IIz system
  Back to Forum: Speakers
