1394 HDDs
post #1 of 5
This forum seems to be dying but I guess it's worth a shot in the dark. Does anybody know if they make a portable HDD with a firewire port. I don't want one that needs to be plugged into the wall but rather just get it's power from the firewire port on my laptop. Or if there is a such an animal as a firewire to mini-usb cable, I can use that as well. Thanks in advance.
post #2 of 5
I "rolled my own" portable Firewire+USB hd over a year ago using this:
http://www.newegg.com/Product/Produc...&Tpk=PHR-250CC
I combined that with a Western Digital 250gig laptop 2.5" HD 5400rpm and it's worked famously as a portable music archive.
It will power up over Firewire without a supplementary power supply. The same is not true when using USB, you will need the USB "power lead" in addition to the USB data lead.
post #3 of 5
Do you know what kind of firewire port that case has? I only have mini firewire on my laptop.
post #4 of 5
That enclosure has the standard 6P female connectors (x2).
To connect to a 4P iLink style laptop connection you would need an adaptor cable like this:
http://www.monoprice.com/products/pr...t=1#largeimage
Using a 4P connection you will not have the 30v DC + ground that the 6P connector uses. In this case you will probably have to supplement the drive with the USB power lead.
post #5 of 5
Interesting; I just may try that.
