Originally Posted by Rojo_P
From reading the posts here can I assume no one has attempted a 320GB drive in the 3090 from some manufacturer other than Seagate?
Also, is anyone having an issue with the 3090 and fast forwarding through commercials, and not being able to control where it stops? I had the SA8300HD until 6 months ago and I was fairly adept at stopping the thing when I saw the original program continuing. The 8300 would rewind enough to show the program, but this Sammy is all over the place.
I had the 8300 taken out because it missed recording a few shows but it was a much better box from a DVR function perspective. The quality of the picture was also better than the 3090.
The 8300 would reboot a lot.
Just my two cents but none of them work, the software is defective and the hardware is cheap.
The Fast Forward thing on the 3090 really bothers me... You can't stop it!!!!
Time Warner Cable - North NYC
. I guess they're trying to unify both SW versions. The 3270 ran SW v4.2.x but not v2.4.x. The 3270 runs a very similar CPU and it must have identical components to the 3090.
