AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *OFFICIAL* Denon AVR 1910/790 Owner's Thread
*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 6
post #151 of 9199
[quote=SoundofMind;16625243][quote=strangelet;16624457]Just received my AVR 1910 a few days ago. I'm experiencing a perplexing problem: when my TV is turned on, I get no audio via HDMI either through the amp or the TV...When the TV is turned off and the Blu Ray player/1910 are on, the sound is fine - the 1910 indicates that it's outputting Dolby Digital...When I turn on the TV, suddenly the audio is dropped and the 1910 acts as if it's getting no audio signal, but the video is outputted to the TV.
Here's one idea: try setting HDMI control to OFF, see p 28 of OM.
Thanks for the the suggestion. The HDMI control is set to OFF. I also tried turning it on, but I get the same result.
post #152 of 9199
Great minds think alike. Well, I guess it's time for greater minds/expertise to weigh in. Where's bp and jd today? You guys got something better to do?
edit: describe what is hooked to what thru what
post #153 of 9199
[quote=strangelet;16626293][quote=SoundofMind;16625243]
Also check Power Off Control, set to "ON"
post #154 of 9199
Originally Posted by Davidt1 View Post
I have some more questions about the 1910.
Does the remote control have dedicate buttons for the dimmer and sleep timer? Or do you have to go into some menu to activate them? Thanks.
The remote (back) has the dedicate button for sleep timer (see page 7 in Owner's Manual). Control for dimmer is only on the front panel of the unit AFAIK.
post #155 of 9199
dude, I'm on the west side! I was sleepin', it's early out here!
honestly, I have NO CLUE. that is a bizarre one and I've never seen anything like it!
post #156 of 9199
Originally Posted by Waidulis View Post
At the moment I have 2 sources and TV:
1. Home PC with just S-Video out, SPDIF (seems not optical) out.
2. Asus laptop with HDMI out, VGA out, SPDIF (optical) out.
3. TV the old one with just S-Video in, SCART, analog connections in (white/red/yelow).
My concerns and questions are:
1. As my TV don’t have HDMI, it seems I can’t hook any video source (in egz laptop) through HDMI…If I connect video sours via HDMI I need to output through HDMI as well. Am I correct?
2. From Q1 follows: Can I connect laptop to avr with HDMI, play video source, but just listen the audio from the source, and not require avr to output picture via HDMI? Does 1910 will do it for me? Can I use the same HDMI permanent connection (avr - laptop) just for audio source listening?
3. Am I correct 1910 has only 1 S-Video in, and just ONLY for ipod dock control (from the 1 post)? It means I can’t connect PC to avr via S-Video? Sure I can connect PC directly to TV, but again I just wonder…
Thank you for the help
unfortunately, the 1910 will not be useful for your setup (which is mostly S-Video) if you intend to use the 1910 as a video switch.
Can you just hook up the video directly to the display and hook the audio (SPDIF) up to the receiver? The 1910 has four digital audio (SPDIF) inputs so there is plenty of capacity.
in terms of video switching, these new receivers are really geared towards HDMI setups with support for only a few legacy devices.
post #157 of 9199
Batpig, you have to give equal services to the east coaster as you give late services to west coasters
Late services don't serve us much, cause were're sleeping.
Just pulling your leg, your help is much appreciated in matter of fact Denon should pay you for such services.
keep up the good work
post #158 of 9199
Bitpig. When i tell harmony to upload your denon 2308ci settings, will i have complete control over the 1910? Or would it be better to use thier 1910 settings. Also, when under devices, will it be listed as 2308ci, or can i change that name? (i dont yet have my harmony one)
post #159 of 9199
yes, the whole point is to get the most control possible. If you use "AVR 3808CI" as your device name (not 2308 FYI) you will get a huge library of commands, which I have comprehensively listed in the link in my signature. You can then rename it to whatever you want.
The Harmony nor the Denon cares not what name you use in the database, since all the IR commands are the same. The point is to get MORE of them.
post #160 of 9199
Deciding between the 1910 and 1610. Leaning toward the 1610 as I don't need 7.1 and 3 HDMI inputs are more than enough for me. What I need to know is:
Is the Audyssey stuff the same on both receivers? Thanks.
Also, do these receivers require a display to do the setup? What I mean is on some receivers I can setup by using just the display on the receiver. Thanks a bunch.
post #161 of 9199
so should call harmony, and tell them to transfer batpig's denon 2308CI device to my file
post #162 of 9199
correct, that would work -- but note that it is 3808CI (not 2308).
just ask for the entire "AVR 3808CI" device profile from username "batpigworld" and you will have a huge catalog of IR commands at your disposal.
post #163 of 9199
Yes, as indicated in post #1
it's not REQUIRED but it is way, way easier to do with a display connected. don't you have a display you are using this with? even if it's an old TV with composite or s-video input you can see the display.
post #164 of 9199
Deciding between the 1910 and 1610. Leaning toward the 1610 as I don't need 7.1 and 3 HDMI inputs are more than enough for me...
I'm also trying to decide between these two. The 1610 is equipped with all the connections and functionality that I require. The only thing I'm concerned about is the power rating between the two. Could the 1610 drive these speakers LOUD without working too hard? Would the 1910 sound slightly better at a higher volume? Anyone have an opinion? Here's the lowdown on my setup:
Room size: 12' x 13' (approx.)
Speakers (all paradigm except sub)
Front: Titan Monitor
Center: CC-190
Rear: Atom Monitor
Sub: Quest 8" powered
Initial pricing in Canada is $699 for the 1910 which is a little steep but I could convince myself if need be.
post #165 of 9199
the power difference is pretty minimal, especially in that small of a room. The difference between 70W/ch and 90W/ch is less than 1dB. You would need to DOUBLE the power to gain a 3dB increase.
The 1909 would theoretically play SLIGHTLY cleaner at SLIGHTLY higher volumes, but the power difference is mostly negligible.
See the "how much power do I need?" section of the AVR FAQ for more info.
post #166 of 9199
As a small thank you for the help on this board, I would like to point out for those considering the 1910/790, either against the 1610 or others, that Beach Audio has 1 (!) 790 in stock for a good price. Just bought mine! Couldn't pass up the future 7.1 insurance for $65 more than the 590.
Thanks to batpig for all the help as usual!
post #167 of 9199
Uh-oh . I'm getting the exact same issue. And the one common theme between our setups is the Sony TV (mine's a KF-50WE610, which only has DVI, not HDMI, though). I believe Denon screwed something up in the HDMI negotiation as far as capabilities go. The behavior is quite strange depending on which piece of equipment I'm communicating with:
Tivo HD: Sends over 2-channel stereo with TV connected. Disconnect the TV and now it jumps to 5.1 DD (same recording, never even stopped playing).
PS3: With TV connected, cannot even set audio to HDMI -- PS3 claims that audio is not supported over the HDMI interface (worked fine with this TV with the other 5-6 HDMI receivers I've tested).
Oppo DV-980H: Will not send any audio when TV is connected. Disconnect the TV and it plays stereo and multi-channel fine.
I've tried all of the HDMI control settings, but nothing seems to resolve this issue. Does anyone out there have any other ideas? I'm going to be quite upset if I have to pay return shipping and 6ave's 15% re-stocking fee. Grrr...
Just received my AVR 1910 a few days ago. I'm experiencing a perplexing problem: when my TV is turned on, I get no audio via HDMI either through the amp or the TV. Allow me to explain:
THE SETUP:
Denon AVR 1910 connected to Sony KDF-E42A10 TV via HDMI
Panasonic BD-60 Blu Ray player connected to AVR 1910 via HDMI port 1
Xbox 360 connected to AVR 1910 via HDMI port 2
The 1910's "hdmi audio out" setting is "amp."
When I turn on the TV, suddenly the audio is dropped and the 1910 acts as if it's getting no audio signal, but the video is outputted to the TV. I go to "Information->Audio Input Signal" and no signal is shown. Also the 1910 doesn't seem to be passing the audio to the TV (just to clarify: I don't want it to pass the audio to the TV, would rather have it outputted via the amp.)
Same issue occurs with the Xbox 360.
BTW the Blu Ray player's "digital audio output" setting is "bitstream" and the "hdmi audio output" is set to "on." The Xbox 360's digital output setting is "Dolby Digital 5.1."
Any ideas would be much appreciated!!!
post #168 of 9199
He does not say but he may have a front projector that makes a little noise. What I do is turn is turn it off at the point where you begin the test chirps and just press a button.
post #169 of 9199
has anyone used the dolby pro logic IIz feature?
i have a few questions. Firstly i will be using a ps3 as my bluray player. This means audio will be outputted as LPCM/MPCM.
1)Can PL IIz work WHEN getting a LPCM siganal from the ps3???
If #1 is yes then continue with these questions
2) Does it work WITH dts-ma, true-HD, and PCM tracks. As in if i play a 5.1 trueHD track/ 5.1 DTS-MA track, will i be able to add the plIIz to it and matrix in the height speakers.
3) How would this height configuration work when i send a 7.1 DTS MA signal to it.
The information you guys give to me will help me decide whether or not i will buy 2 more speakers as height. In my house a traditional 7.1 set-up would not work. Luckily, my house is wired in such a way that 7.1 Height would. So for me it is either 5.1 or 7.1 IIz
post #170 of 9199
1) yes
2) yes (but it doesn't matter for you as the PS3 doesn't bitstream, it will all be PCM)
PLIIz will work with any 5.1 signal just like PLIIx
3) you would not send a 7.1 signal to it. all HD codecs are mastered with both a 5.1 and 7.1 mix on the disc, so there is no need for a "downmix" when you are using a 5.1 system. if the PS3 is configured properly (uncheck the 7.1 output options), the PS3 will automatically select the 5.1 track off the disc, decode to MPCM, and the receiver will get a 5.1 PCM signal regardless of what HD audio source you are listening to.
post #171 of 9199
so i want to tell the ps3 to send a 5.1 signal only. This will not be a problem even with 7.1 blurays as they have a 5.1 track on them which is of the same quality. Am i correct in saying that?
Then the denon will add height channels to them
post #172 of 9199
so far what you have told me is quite relieving. As i now know that i will be able to use the denon to full capability (as far as # of speakers being used)
post #173 of 9199
If i did send a 7.1 signal. What would happen. Would i start to get rear sounds comming from infront of me?
Also, when gaming, most games are in dolby 5.1 digital. I take it that the denon will mix it into 7.1 height. Which mode on the receiver do u recommend. As in do u recommend that i use the "game" mode, or leave it regular.
post #174 of 9199
I went to Denon's site and don't see Beach Audio listed as an authorized dealer. What are the ramifications of buying from some company like this? (from the reviews they appear reputable. Also, I could have misinterpreted, but I don't think their shipping return policy is as good as JR or 6th who pay for return shipping if there's a problem and are authorized dealers)
post #175 of 9199
Correct. All 7.1 discs have to be fully backwards-compatible with 5.1 since the vast majority of setups are only 5.1. As a simplified explanation, the way it works is the lossless soundtrack is encoded as a 5.1 track and then there is a 2-ch "extension packet" which contains the information for turning the two surrounds into four discrete channels.
If the PS3 knows you have a 5.1 system, it will automatically select the "correct" track off the discs.
No, of course not! The receiver will "know" you have height speakers and not rear speakers because of the way you set the AMP ASSIGN. If it does get a 7.1 signal, I imagine it will simply "downmix" to 5.1 and then matrix the height channels.
The PLIIz matrixing of the height channels should not be impacted by 5.1 vs 7.1. Either way, it won't put stuff that is supposed to be behind you out in front of you...
I got no idea!! You will have to play around and see what you like, this is a brand new technology
Anyway, I don't think PLIIz has "music", "game", and "cinema" modes like PLII/x. Perhaps I'm wrong, but I don't really know exactly how it works.
post #176 of 9199
Beach Audio gets good reviews at ResellerRatings.com and as long as you keep your receipt and the serial number is in tact, you shouldn't have any problems getting warranty service if required (not guaranteed, but most likely no issue). Still too early to know if there are any problems with the 1910.
post #177 of 9199
Strange to be sure!
If you haven't already done it, Reset the Microprocessor and see if that solves your problem.
post #178 of 9199
I know we cant talk of price but lets just say that i got $100 off MRSP from six ave's (autherised dealer) name your price promotion going on this week only.
Perhaps that puts it into good pricing with beach audio.
post #179 of 9199
Dolby Pro Logic IIz Benefits
- Realistic and involving surround sound from any music, movie, or video game source (so therefore no separate modes like "music", "game", and "cinema" like PLIIx)
- Dramatic alternative listening perspective for installations that can't accommodate back surround speakers
- Functions with original stereo or multichannel sources
Unlike other solutions, Dolby Pro Logic IIz does not employ digital signal processing (DSP) to artificially model a room environment or create ambient sound effects. Instead, Dolby Pro Logic IIz identifies nondirectional, decorrelated signals naturally present in the mix (such as some audio elements in wind noise, musical scores, and other ambient sounds) and extracts them for presentation in the height channels.
Gaming mixers will also start including Dolby Pro Logic IIz specific information into future video games as well.
post #180 of 9199
or if u dont want to buy from a reputable dealer. You could add the three year warrenty to it for $40
But that puts it like $20 cheaper than 6th ave. In this case just buy from 6th ave.
