Originally Posted by jimlad2000
Hi everyone just bought then 1910 but am having a little difficulty
I have my xbox 360 connected up via component to my 1910 then AVR to Panasonic PH9 via component, sound is via optical.
I know the screen should blank out when I press the menu button then I should get the white on black OSD but for some reason I dont any ideas?
I'm not really worried about the OSD but it would make the inital setup that bit easier when calibrating rather then using the front panel
Se Page 9 of your Manual. My XBox360 is connected via Components to the AVR but the output is through a single HDMI cable. I get the OSD with no problem.
The Manual says that to get OSD with component connection you must connect the video terminals
For a non-HDMI display looks like you need to connect a standard (yellow) composite cable for OSD.
