I wouldn't recommend simply "blowing" into the headphone jack (rather use compressed air) as you very well may have introduced moisture from your spit which may have resulted in a short circuit. Try inserting/removing the headphone plug a few times and see if that resolves the issue. If not, try a microprocessor reset and if still no joy ... pop the top and see if you can find a blown fuse. If still no joy after all that, then likely it's either repair/replace. If outside the 2 year warranty, and you purchased with a credit card, check with your card provider as they may add an additional 3rd year of warranty (Amex does this and some MC/Visa providers do as well).
post #8791 of 9218
12/2/11 at 3:53am
