AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *OFFICIAL* Denon AVR 1910/790 Owner's Thread
*OFFICIAL* Denon AVR 1910/790 Owner's Thread - Page 303
post #9061 of 9206
Denon AVR790 No longer getting digital Opt2 signal on Sat/Cable (have it hooked up to switch that goes into roku, tv etc).
It says auto but then defaults to analog.
Also no longer getting digital Opt1 signal on VCR/Ipod hooked up to airportexpress router. It does not even
say auto, just defaults to analog. Checked input menu and opt1 is selected for that input.
This was working yesterday. Wonder if I accidentally pressed something on the remote? Or did something
blow in the receiver?
Looked at both optical cords and ends show red before plugged into receiver. Receiver opt1 and opt2 input
holes are dark.
Any ideas?
thanks in advance
post #9062 of 9206
holes are dark.
Any ideas?
thanks in advance
Hi bluen, try bypassing the optical switch with direct connect. And try cycling Input Mode button on remote to "Digital".
post #9063 of 9206
thanks, worked!!!
post #9064 of 9206
More questions about using the remote:
The display on the receiver is off while the unit is still on. This never happened before. How do I get it to stay on?
If I use the quick select buttons on the remote, how do I make sure the mode remains on digital?
I must say this remote is confusing, I was doing better when it was lost...
post #9065 of 9206
Hi bluen, its possible you may set surround mode to "Pure Direct" and enabled it. Try pressing the "Pure" button at the back of the remote.
post #9066 of 9206
After adjustment you'll need to memorize it by pressing the "Quick Select" button down and holding it a few seconds until the displays flashes.
post #9067 of 9206
Worked, thanks!
I like the receiver but the remote is a challenge.
post #9068 of 9206
Really hoping that someone might possibly have a solution for me. Recently my 1910 has been having problems where it kicks in its protection circuit at any high action point of a movie. Like i was watching start wars episode 1 the other day and everytime anything even started getting intense it kicked off. At first i thought maybe it was just the HDMI cable but then later that day roommate decided to hook his laptop up to the TV to play some diablo III and it kept doing it as well using a different HDMI cable on a different HDMI input. Any thoughts as to what i should check to resolve this as its getting annoying that we have to keep the volume around 30(which is just about inaudible) to be able to actually watch movies.
post #9069 of 9206
The most common reason for shut down is a loose speaker wire from one post touching another post. Check all posts both at the AVR and each speaker to visually confirm whether this is the case or not. When the AVR shuts down, is the red power ring light flashing about every 1/2 sec or every 2 sec as the latter would indicate ventilation issues if there is insufficient clearance around the AVR to exhaust heat. Is the volume you refer to "30" or "-30db"?
post #9070 of 9206
you know what, i'll have to check speakers, we got yelled at for excessive volume and i believe i just unplugged some of the speakers at the speaker versus the receiver, so i guess it is quite possible that some of the banana plugs are touching haha.
post #9071 of 9206
Yup .. that would do it, especially as the volume is raised to a higher level. wink.gif
post #9072 of 9206
Before I reset the microprocessor, I'm wondering if there's a simple solution to my issue. When I'm on the input for my HTPC (audio only through HDMI-1), the display of the Denon 1910 is off unless i change the volume at which point it comes on but then quickly goes out after I stop adjusting the volume. All the other inputs are on all the time. I've tried hitting the dimmer button but it has no effect. Is there something simple I'm missing, or do I just need to reset?
post #9073 of 9206
sounds like you are in PURE DIRECT mode. Turning off the front panel display is one of the "features" of this mode.
post #9074 of 9206
Well, I think you're probably right that it's in Pure Direct Mode, but it won't let me switch out of Pure Direct Mode, which is the real problem. Thanks for the suggestion, guess it's time to reset it...
post #9075 of 9206
Hi purplestallion, not even the "Pure" button at the back of the remote?
post #9076 of 9206
I have an AVR-1910. Can I watch a movie using Zone 2 + Subwoofer pre-outs with a 2.1 setup. I would like to use my reference monitors and of course they have built-in amps. I would also like to use Audyssey MultEQ. Will this work? Thanks.
post #9077 of 9206
What's the goal? To setup the 2.1 in another room? Audyssey wouldn't apply to the Zone 2 speakers, although you could split the sub pre-out using a "Y" splitter.
post #9078 of 9206
yes, please take a step back and explain your entire setup and your goals. It's very difficult to give advice when we are clearly only getting a fraction of the story.
post #9079 of 9206
2.1 as the main setup, wanting to use the zone 2 since there are no main pre outs, that's all.
post #9080 of 9206
Ah ... okay, then no, you can't use Audyssey with them connected to the Zone 2 pre-outs. You also won't be able to pass any HDMI or optical audio inputs to them, rather analog only.
post #9081 of 9206
bummer, maybe should trade up to $500 AVR-3311CI then. Any cheaper alternatives?
post #9082 of 9206
Sorry that could have gone off-topic, never mind about the 3311... but since I cannot really justify a new receiver right now, instead of using 2.1 with my studio reference monitors, I would like to use my Energy Take Classic 5 speakers, but in 3.1, is this possible? I don't want to run wires all over the place because this is a temporary setup and there will be lots of people around to trip over wires.
The Energy Take 5 (I actually have 7) has 6 identical speakers + a center. For bigger sound, can I leave out the center speaker, and use the other 6 (2 + 2 + 2) for my LCR, and wire in parallel as long as I keep the volume below distortion? They are 8 ohm speakers so load will be 4 ohms. The speakers are small. I could also wire in series for 16 ohms but I will be cutting my power in half. What do you recommend?
If this won't work I'll just do 1 speaker on each channel in 3.1. And if 3.1 is not possible I will just do 2.1, which I know is possible. smile.gif
Thanks for advice.
post #9083 of 9206
Yes, you can use the Energy setup in 3.1 only, although you're likely better off sticking with traditional 3.1 rather than your 2+2+2.
post #9084 of 9206
cool! (to 3.1)
awwww smile.gif (to 2+2+2)
post #9085 of 9206
The "Pure" button worked after all. I feel like an idiot. I could have sworn I tried pushing it before with no luck. I was really happy not to have to reset everything. Really happy. Thanks for the help.
post #9086 of 9206
How can I hook up hearing assist wireless headphones to my system?
Sennheiser Set 830-TV Wireless TV Headphones
Denon AVR-1910
Samsung UN46 B6000VFXZA 46" LEDTV
Samsung BD-P 1600 BluRay
Phlips DVP5982 DVD
U-Verse IPTV
Over air TV
VCR
Uverse, the disc players ,& the TV are all hooked up with HDMI,
Over Air uses TosLink back to the AVR
If I use the Headphone Jack on the Denon the speakers turn off and no one else can hear.
The sound doesn't seem to be passed through to the headphone jack on the TV.
The analog outputs don't get the HDMI audio passed through.
Damn you HDCP
I am considering trying a toslink SPDIF to Analog Audio Converter like this one
http://www.amazon.com/Digital-Optical-Toslink-Analog-Converter/dp/B004C4WPXA/ref=sr_1_1?ie=UTF8&qid=1345924935&sr=8-1&keywords=toslink+to+analog+converter
on the digital output
Does anyone know if that will work
Otherwise I think I need an analog switch box for the devices I want to work with the Headphones.
Thanks for your help.
post #9087 of 9206
You'll want to connect the headphone transmitter into the Zone 2 pre-out jacks (set Zone 2 ON) and then connect any sources you want to pass to the headphones with an analog cable (red/white) in addition to the HDMI cable for the main zone as only analog sources will pass to Zone 2.
post #9088 of 9206
Yes, but there are not corresponding analog inputs for every HDMI input.
Also curious if the converter idea would work.
post #9089 of 9206
The HDMI inputs are "assignable" whereas the analog inputs are not, so simply assign them to the same name used by the analog input's source name. And yes, the optical--> analog converter connected between the TV and AVR would work, although likely not necessary as the TV likely has analog audio outputs as well.
post #9090 of 9206
What I meant was to hook the headphones up to the optical to analog converter and connecting the converter to the optical output on the Denon AVR-1910. If all inputs will play through the optical output that might be the easiest way to hook it up.
Running analog cable (red/white) from the TV to the Denon would involve opening up the wall to fish another set of cables through.
If I can play all inputs (Digital & Analog) through the optical output on the Denon via the optical/analog converter then that would be simpler.
edit
Even if only the digital inputs played through the optical out then that would cover most of the often used listening modes.
Edited by yrog - 8/26/12 at 12:02am
