AVS › AVS Forum › HDTV › HDTV Technical › Using TSreader to determine ATSC PSIP table contents
post #1 of 5
I'm trying to sort out what I think are atsc psip table problems. Will Tsreader lite give them to me or do I need to get one of the more advanced versions?
Also, a lot of the Tsreader supported hardware have system requirements beyond what my old pc has, but if I'm just using the hardware for tsreader input data and not to view/record tv programs, etc, will I be ok?
post #2 of 5
TSReader Lite should tell you everything you need to know.
I've used TSReader on computers that cannot decode HD streams with any success, so I think you'll be alright.
I use it a lot, so if you have any trouble, let me know.
- Trip
post #3 of 5
Yep - I used TSReader (the cheaper of the two paid-for versions) to record 18Mbs H264 HD DVB-T OTA streams off-air on a Celeron 733MHz 256Mb RAM laptop with no problems - and there was no way it could decode those.
It's a fantastic bit of software.
post #4 of 5
I also use TSReader (Pro) daily.
Tuning/monitoring HD streams is no problem even on older systems, and is dependent on HDD performance (for recording) as all you're doing is saving a file. Decoding is where you need a newer system. You should be fine.
post #5 of 5
Thanks guys, it seems to be working well for me now.
  Back to Forum: HDTV Technical
