AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *OFFICIAL* Denon AVR 1610/590 owner's thread
*OFFICIAL* Denon AVR 1610/590 owner's thread - Page 68
post #2011 of 5188
FINALLY found where to turn Viera-Link off...didn't help. Will doing the processor reset clear all my set-up and Audyssey settings?
Turn HDMI-CEC to OFF on your TV. If still no joy then do the 590 Reset the microprocessor procedure (p. 57).
post #2012 of 5188
If your BDP is really set to PCM, audio volume shouldn't be a problem, otherwise if it's set to bitstream there would be a problem as you describe. What is showing on the AVR display? MULT CH IN or the "HD Audio light"? If, the blue light, you need to set the BDP to PCM, otherwise, do Reset the Microprocessor (p. 57).
If i set the player for bitstream, the blue HD light is lit but I dont get volume until about +2. If i set the player to PCM it just says MULT CH IN and the volume is fine. Sorry about the confusion. I had it backwards in my op post. I do have the older firmware though. 0.81
post #2013 of 5188
Yes, resetting Microprocessor will reset all settings back to their default settings including having to do AUTO SETUP again.
post #2014 of 5188
Not sure what I should be expecting so maybe this is normal. When watching my Cox DVR I have the volume set to -20 to -15 or so and it's a very tame level. In order to get some good dynamics I'm up to the -5 to -10 range. This is with Dynamic volume off. Turning it on just drops the level of all programming and really kills it.
I just tried a little Gladiator on DVD. Sounds good if I run it up at -10 or so.
post #2015 of 5188
that is normal, this has come up a dozen times in this thread already
post #2016 of 5188
This is normal like batpig mention. I normally have Dynamic volume "ON" with a "Evening" setting (Midnight is default) when watching cable.
post #2017 of 5188
Just to clarify... If the 1610 shows MULT CHNL IN it is HD audio?
post #2018 of 5188
If you have the HD audio track selected on a Blu-Ray and the BDP is set to PCM, then yes.
post #2019 of 5188
Okay. One last question. Is there a difference in sound quality from the decoder in the blu-ray vs the 1610? And how do I know for sure if its just not a reg 5.1 track? For example, Star Trek only has the 5.1 hd audio selection and a few others in different language. When I play it on my older Yamaha DSP-A1 via coax, its just reg DD.
post #2020 of 5188
The decoding process is the same .. whether it's done at the AVR or BDP, just like unzipping a computer file. The process doesn't change the file, it simply decompresses it. When the BDP does the decoding to PCM, you should be able to see what the audio track is that's being played on the BDP, whether it's DD/DTS 5.1 or an HD Audio track. In the case of using coax, the best that coax can transfer is DD/DTS 5.1 or PCM 2.0, so if you're playing a Blu-Ray it will play the legacy DD/DTS track instead.
post #2021 of 5188
Hey all, just picked up the AVR-590 at Fry's today... And it's up and running with no problems, though I've got a lot of reading and experimenting to do in the coming days/weeks....
No subwoofer at the moment, but I don't think I need it with my speaker set up:
Front L/R: B&W DM330
Center: Infinity Video1
Rear L/R: Audiosource LS100
I'll try to to read all 68 pages for pointers and advice... Gulp.
EDIT: BTW, the link at the top of the first page for batpig appears to be dead: http://www.avsforum.com/batpigworld.com/
post #2022 of 5188
Thanks - just have to adjust my mental calibrations then. On my old AVR -15 or so was rocking the house.
post #2023 of 5188
Really? Are you trying to measure in the next room? That mic cord is 25' in length and the average distance from the couch to the TV is 10'-15'?
If you really need an extension you can get a 3.5mm extension cable in numerous places including Radio Shack.
Haha. All my stuff is in a closet 35 ft away from the screen/projector. So the mic barely made it to the 1st position! I found an extender on monoprice! Thanks for the help!
post #2024 of 5188
The link still works. It should just be http://www.batpigworld.com without the avsforum part.
post #2025 of 5188
Yup.
I used the link in his signature.
post #2026 of 5188
I was wondering if I input component with 1080p would it come out hdmi as 1080p just like the 790 model and up?
post #2027 of 5188
The 1610/590 does not offer any scaling ability so therefore whatever video resolution "goes in" also "comes out" the same resolution.
post #2028 of 5188
Alright thanks because I heard last year models of denons had problems with 1080p component thru hdmi.
post #2029 of 5188
Last year's models explicitly could not convert 1080p component to 1080p HDMI output. It was mentioned in the manual, but AFAIK that language disappeared from this year's manuals. However, I don't think anyone has put it to the test with a new 590/1610 model so it is somewhat uncharted territory... sounds like you want to be our guinea pig!
post #2030 of 5188
Well my Denon want be here till next week, this is my first receiver, so I am very anxious to play with my new toy lol
post #2031 of 5188
Is there any way to run a video signal into the receiver via HDMI and run audio in through an RCA or alternate connection?
I am trying to play video out of my Macbook Pro.
I'm connecting mini display port to HDMI from the macbook into the receiver and stereo mini from the headphone out to L/R RCA into the receiver. Both connections work but not at the same time.
I've had a long, headachey day with a bunch of new cables that I thought were going to make everything shiny and wonderful...
...any suggestions?
post #2032 of 5188
Correct. The RCA inputs are not assignable so you have to plug in to the same labeled RCA jacks as the HDMI jacks you have the computer plugged in to (ie HDMI jack = DVD, RCA jack = DVD). Not sure if you're trying to get audio routed to the TV speakers, however, only HDMI audio IN can be routed via the HMDI Audio Out set to TV setting.
It looks like my question was already answered a ways back. These bleary eyes missed it on first glance.
I'm hoping to get a mini TOSlink cable to output from the MBP tomorrow to get a better line out of the computer. I assume I can simply switch the audio input assignment to the optical line instead.
post #2033 of 5188
Correct. For the source name you use for the MBP, just set Input Assign (Digital) to whichever optical input you are using.
post #2034 of 5188
Like I suggested to the other guy, turn the HDMI-CEC setting to OFF on your TV (Samsung - Anynet+, Panasonic - Viera Link, Sharp - Aqous Link, Sony - Bravia Link). Also, give the HDMI Reset procedure below a try:
Thanks, but it didn't work, the tv still turns off and on it's like if it receives some sort of input although all possible HDMI controls are set to off....
I even thought it could be an electrical problem but the tv is on its own outlet.
It's giving me headaches as i cannot think of any reasonable cause for this...
Edit: the behaviour is the same as when the power goes off for a millisecond, not enough to make it turn off but enough to "restart" it.
post #2035 of 5188
So you have Anynet+ set to OFF and tried the HDMI Reset procedure? Try turning HDMI Control OFF on the AVR as well.
post #2036 of 5188
Yes, tried the reset procedure and turned off HDMI control on the devices that have this option ( Samsung Anynet, PS3, AVR ). It must be something outside the normal functioning, that's why it happens randomly and isn't always replicable.
post #2037 of 5188
Suggestion:
- check model Tv for any firmware update
- remove all source except one and see if the problem reocccur
- if problem doesn't occur, connect another source and so on
post #2038 of 5188
Originally Posted by googlegod View Post
These settings work perfect for your Sony
Audio Output Priority - HDMI
Audio HDMI - Auto
BD Audio Setting - Direct
Dolby Digital - Dolby Digital
DTS - DTS
48/96khz PCM - 96khz/24
The Denon HD Blue light will be glowing, just be sure there is a HD disc in the player
I tried these settings on my Sony 460 and they worked. Let there be Blue Light!
post #2039 of 5188
Does the TV shut off only when the DVB-T box is being used? Are you using a EU 1610 as it seems the DVB-T box is a European box?
post #2040 of 5188
Set up my HT with the 1610 yesterday for the 1st time. Everything worked beautifully. I just have Dish and Blu-ray set up with the receiver/tuner.
I had Q. selects for each, 1 for BD, 2 for Sat, and 3 for tuner. While making some audio changes and saving them in memory I inadvertently hit Q. select 1 to save the settings for Sat. This, of course, gave me 2 Q. selects for Sat and none for BD. At first I wasn't sure what I had done so I'm not sure what all I did, but eventually I used the Source Select button to get to the BD. All I got was a blank screen like the HDMI wasn't even connected. Did a lot of reading and came across the area about input source on page 31 and figured I must have changed it to something other than HDMI. Went into the menu and was surprised to see it on HDMI, nutz! On a whim I changed it to auto and voila, the BD came on my screen. A little later, not sure what I was doing in between I went back to it and it was back to HDMI but I could still see my BD on the screen. Of which I was glad but had to wonder why it wasn't showing with HDMI before but is now.
Not gonna lose sleep over it but I sure am curious what may have happened.
