AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *OFFICIAL* Denon AVR 1610/590 owner's thread
*OFFICIAL* Denon AVR 1610/590 owner's thread - Page 11
post #301 of 5128
Originally Posted by batpig View Post
no, with the advent of HDMI more and more entry-level receivers are dropping multichannel analog inputs. On Denon's current lineup you need to step up to the 790/1910 model for multich analog inputs.
unfortunately, the Denon 1930CI can't do SACD over HDMI. Optical will not get you multichannel hi-rez sound, only 2-channel. You may want to consider either (1) selling the Denon DVD and switching to an Oppo or some other player which can do SACD over HDMI or (2) going with the 790/1910 model.
Thanks, the 590 fit my budget but if it isn't what I need I might have to wait a bit and pick up the 790.
Mike
post #302 of 5128
you can find the 790/1910 model for under $400 if you look, read up in the owner's thread and there are good deals out there from authorized dealers like 6ave.com and electronics-expo.
post #303 of 5128
Received My Avr 1610 today. Can't really test it since my speakers are in France and I'll be heading there in about two weeks. But Seems to decode HD sounds and powers up...
By the way I don't know if I speak the Denon but I found the manual's owner pretty good with no complicated things.
Maybe they have better french translators.
And UPS was fast. Shipped on UPS ground from Electronics expo on the 30th. Received today the third. With the w-e in the middle.
post #304 of 5128
I'm not sure if I should post this here or in the subwoofer forum, but since it involves my new 1610 I'll start here. I followed the directions in the Denon owner’s manual, and ran the automated speaker setup, all my speakers (Front = Bose 301, Center = Optimus, Rear = Optimus) are set to small, and my subwoofer (MTX SW2) is set as follows:
Subwoofer: On
Phase: 0
Crossover frequency: 160 Hz (speaker can be set 60, 80, 120, 160)
Volume is set to the 12 o’clock position
My problem is when I watch my DVD’s / Blueray movies I don't seem to have much low frequency response. Highs sound better than ever, but lows are sorely lacking (I'm not even sure my sub is doing anything). If I change the front speakers to large things sound better, but not great.
I guess what I’m trying to determine is whether or not I’ve configured my speakers corretly?
post #305 of 5128
Originally Posted by oconnells View Post
I'm not sure if I should post this here or in the subwoofer forum, but since it involves my new 1610 I'll start here. I followed the directions in the Denon owner's manual, and ran the automated speaker setup, all my speakers (Front = Bose 301, Center = Optimus, Rear = Optimus) are set to small, and my subwoofer (MTX SW2) is set as follows:
Subwoofer: On
Phase: 0
Volume is set to the 12 o'clock position
My problem is when I watch my DVD's / Blueray movies I don't seem to have much low frequency response. Highs sound better than ever, but lows are sorely lacking (I'm not even sure my sub is doing anything). If I change the front speakers to large things sound better, but not great.
I guess what I'm trying to determine is whether or not I've configured my speakers corretly?
In the Manual Setup for Bass, choose the LFE+Main setting. This will make your sub play the dedicated low freq channel + the crossovers from all your main speakers. Also, try turning off Dynamic Volume if it's on.
post #306 of 5128
actually, the LFE+MAIN setting does nothing if his speakers are set to small! It's only relevant for speakers set to LARGE, it's basically the "double bass" setting which allows the subwoofer to play not only the LFE signals (LFE), but also duplicate the low-freq sound from the main speakers (+MAIN). If the speakers are already set to "small" then the SW is already getting the redirected bass from the main speakers.
oconnells - I'm assuming Dynamic EQ is on (red light) since that is the default setting after running Audyssey. What are your speakers channel levels set to, and what are your crossovers for all of your speakers? When you run the manual test tones (manual setup > speaker setup > channel levels) do you hear the sub rumbling?
post #307 of 5128
This may be a difficult question to answer because of so many variables, room size, source, speakers, etc. I was wondering after the auto setup is finished, what levels it set for you? Also what is the main volume set at for a normal listening level? I have my setup in a 14X12 room. The speaker distances it set seem to be right on but the channel levels are set at - 5 db or less. I have to crank the main volume way up to hear it. Seems this way on my DVR and Blu Ray player. Any insights?
thanks
post #308 of 5128
That is totally normal.
First -- on a receiver with Dynamic EQ, the unit calibrates the volume dial so that "0" on the dial gives you a predefined "reference" volume, as defined by the film industry. This is the volume used in movie theaters and mixing studios where soundtracks are made. Now, this reference volume -- defined as 85dB with 105dB peaks (+20dB "headroom") -- is REALLY LOUD and would be unbearable in most home settings.
Anyway, the volume calibration is a necessary step, because Dynamic EQ works by adjusting the tonal balance of the system as the volume drops below that "reference". If it doesn't know what the reference is, it wouldn't know how much to boost the bass or surrounds as the volume drops.
So, in a small room, with moderately efficient speakers, it is perfectly normal that all speaker volumes have to be trimmed down a bit into the negatives. If you put the same speakers in a huge room, all the values would be positive.
The big difference is that, with most receivers, you simply calibrate the speaker volumes to balance with the other speakers -- in other words they are adjusted to relative levels. On a receiver with Dynamic EQ, the speakers are adjusted not only relatively to each other, but also to that absolute volume level so Dynamic EQ can work properly.
Second -- since the volume is calibrated, and the volume scale works on a proper logarithmic decibel scale, listening at -20 or -30 on the volume dial may seem like "cranking it" because you are close to "0", but in fact it isn't really THAT loud. Every ten decibels is a doubling of perceived "loudness", so if you listen at -30 then you are actually eight times less loud than "reference" or what you would hear in a giant, blasting movie theater.
So in other words, it's all totally normal, enjoy
post #309 of 5128
bose with anything other than bose equipment is a bad combination...
given the amp you have i would suggest us audio or any other brand speaker..
the bose speakers are fitted with fuses and they to blow out when you try to use them under any type of load on any other amps other than bose...
personally i wouldn't buy bose speakers if you paid me..
i wouldn't be surprised to see the fuse fried in the bose apon the connection to the amp..
post #310 of 5128
Hey guys,
am considering purchasing the 1610 to solve an issue w/ my current HTIB setup that's been uncovered since i upgraded from a Sharp AQUOS LCD to a Samsung LED 6000-series HDTV.
The problem is that my DirecTV HD DVR now exhibits some "lip sync" issues on HD channels. I am wanting to know if the 1610 would potentially resolve these via a) HDMI 1.3 auto lip sync spec or b) manual adjustment per HDMI input (i don't see the problem on my other HD sources, weirdly enough)
Appreciate any info! I did a quick search on this thread and came up empty in this regard...
post #311 of 5128
the 1610 has both Auto Lip Sync and a user-adjustible audio delay feature, so yes you can compensate for lip sync problems. However, you should know that with a cable/sat source a lot of times the problem is not only part of the signal, but also variable from channel to channel, so you may end up doing a lot of tweaking.
post #312 of 5128
thanks for the quick and accurate response. what you state is pretty well exactly what i'm seeing. it does indeed vary from channel to channel and, in all reality, is only really noticible on my local CBS HD affiliate - unfortunately pretty much the one we watch the most!
I've called DTV about this, as well as my local affiliate - both report all systems normal
Any further advice, or thoughts about why i never really saw this on my AQUOS LCD but now see it on my LED? (apologize for turning towards being OT for this thread)
post #313 of 5128
it's possibly that it's just a coincidence that you are noticing it now and it has nothing to do with the TV. the fact that it's only really on one channel is a strong indicator that it's not something endemic to the TV or AVR.
post #314 of 5128
any suggestions, then, on how to best go about fixing lip-sync issues that plague a particular channel? would the auto-lip sync of HDMI 1.3 take care of this for me?
post #315 of 5128
presumably, yes, that is what the "auto lipsync" function is supposed to do. however, I can honestly say that I've never used it so I don't know if it will work perfectly for that one channel.
post #316 of 5128
can any users of it help me out?
post #317 of 5128
Thanks for the clear response. It is nice to get an answer that us " tech challenged" people can understand.
One question tho. The setup sets the channel volumes so low that I have to turn the main volume up to -10 for it to be a comfortable listening level. Last time my hearing was checked it was normal btw anyways, Would it be better on the reciever (and sound quality) to just leave it at -10 or to adjust the channel volumes up and turn the main volume down some? I do realize that you would have to adjust them based on the curve that the setup program set. Like if the front was set at -5db and the center was set at -6 db, i would need to adjust everything up 1 db to maintain the difference the program set.
please advise and thanks
post #318 of 5128
I am certianlly not an expert but it seems to me that if its only 1 channel it has to be something not local to your house. Now that you have noticed it try it again on the old TV
post #319 of 5128
I just got my 1610 in the mail. I wont have my 5.1 speakers for at least a week and a half, so I just hooked up my two tower speakers into the front left front right speaker slots. Im only getting mostly backround noise with this setup. I assume this is because the 1610 is set up for 5.1 from the factory. Im new to this so it would be a big help if someone could help me figure out how to get the receiver to switch from 5.1 to a two tower speaker set up.
post #320 of 5128
the tv that i RMA'd for the LED? wish i could!
post #321 of 5128
follow my setup guide:
http://batpigworld.com
and either run Audyssey or use manual setup to set it up for two speakers. set all other speakers to "none" and Front L/R to "large" and you are good to go.
post #322 of 5128
no, just leave it as is. It doesn't make a difference in terms of amp power as the only determinant is the TOTAL gain (speaker level + volume dial). But you will end up screwing with Dynamic EQ's compensation if you raise the speaker levels.
Is Dynamic Volume on when you report having to raise it to -10dB? That would explain that part. Typically, with Dynamic Volume off (and Dynamic EQ on) you would be listening mostly in the -30 to -20 range, and -10 would be pretty darn loud with a movie or music content.
This could also be affected by use of the "Dynamic EQ Reference Level Offset" parameter, which essentially turns down the volume of the source to reduce the amount of "boost" that Dynamic EQ provides.
post #323 of 5128
The Dynamic volume is off. When I turn that on its even quieter. The dynamic EQ is on and the little LED on the front glows orange. Watching a blu ray disc last night "The sum of all Fears" movie, at -20 I was unable to hear the dialog and even the special effects were quiet.
That last part about the "Dynamic EQ Reference Level Offset" I do not understand. Is that a setting? correction?
BTW the exact channel levels as setup on the auto setup are:
FL -6 db
C -5 db
FR -7 db
LS -8 db
RS -9 db
Sub - 8 db
the test tones are plently loud for all channels when testing
thanks
post #324 of 5128
those channel levels all look normal, as I said above. a lot of what will be considered "loud" though of course is going to depend on you and your preferences!
what kind of content are you listening to when you have to push the volume to -10? and what do you mean by "comfortable listening level"? does that mean nice and loud?
the best test will be with content that you know is a at a standardized reference -- basically, a good movie on DVD or Blu-Ray. Pop in a good action flick, with Dynamic EQ on (orange/red light), and -10 should be pretty loud (although not necessarily uncomfortable).
post #325 of 5128
Watching a blu ray disc last night "The sum of all Fears" movie, at -20 I was unable to hear the dialog and even the special effects were quiet. At -10 It was improved to the point i could hear what they were saying but by no means was loud. I also have my Motorola DCH 6416 hooked thru it and its the same. All connections are HDMI
post #326 of 5128
Thanks for your help batpig. Wasnt as difficult as I thought it was to set up. The auto set up is a great feature.
post #327 of 5128
Have you thought about cranking up the center channel to make dialog easier to hear? On the original remote just hit the "CH LEVEL" button (top left from the directional keys) and you can raise the level of individual speakers. Of course, this kind of defeats what the auto setup does...but some movies just don't leave you much choice with their too low dialog audio.
post #328 of 5128
I'm new with setting up receivers so pardon my ignorance. I'm setting up my 1610 with the speakers that I have. I have 2 front, 2 sorround, 1 center and 1 subwoofer. Why is there another set of front speakers terminals in the receiver? Also why is the subwoofer terminal an rca cable terminal? How can I connect the two wires of my sub to the receiver? Thanks in advance!
post #329 of 5128
i'm facing the same dilemma w/ my existing subwoofer. oddly enough every "receiver only" unit that i've seen (ie, not part of a HTIB setup) has the sub as a preamp out RCA jack, not terminals.
I have seen some adapters in various places on the web, even radio shack, but am wondering if there's a better way as well.
post #330 of 5128
Just ran a Audyssey on my 590 with the following results:
Front L & R Speakers: Large
Centre, Surround (L & R): Small
Crossover:
Front: Large Band
Centre: 150 Hz
Surround: 80 Hz
LFE: 200HZ.
What is Large Band?
I have a mishmash of Speakers.
The Fronts are B & W 802, Series 2 (just purchased from next door neighbour for $200).
The Rear are Sonance M30 ( built in came with the house).
The Centre and Subwoofer are cheap Yamaha's. I know I should match the Centre Speaker but I can't afford a B & W.
Any way I really like the Denon 590. For a 5 Speaker setup you really don't need any more.
