Originally Posted by
jdsmoothie
You're less likely to achieve any real benefit using the passive "bi-amp" feature of the 1910. Rather you would benefit more using the surround back terminals for either Front Height speakers or placing speakers in another room.
That is good to know. Do you have any experience with Front Height speakers? Do they really add much? I am torn about what to do. I don't want to spend the $80 more and never use the 7.1, but at the same time, I don't want to not spend it and then wish I had.
The other thing I am a little nervous about is that the 1610 is rated at 75x5 and the 1910 at 90x7. I know ratings don't mean a heck of a lot, but since it is within the same manufcaturer I am assuming the use the same rating standards so I wonder if the 1910 is worth it for the additional 15W per channel.
