Originally Posted by Anthony A.
hi all, i just finally unboxed my 4310 and finishing setup. i have a few questions that were not very clear in the user manual.
1.) surround modes - my setup is 7.1 and i would like to have the audio directly from each disk played such as true hd, dts, etc. (STANDARD setting), but i would also like to matrix the 2 rear back surrounds. what setting must it be to play everything standard but also put the 2 rears to use?
3.) after running audyssey, can you make changes to the system such as making the sub +10db (level matching), crossover, etc. without actually turning off audyssey or does this not constitute a MINOR change?
thanks.
thanks.
1. You'll also want to set the Surround Back multi channel source setting (p. 74).
3. Yes, you can. Audyssey filters still remain in affect. What will turn off MultEQ is if you change (add/delete) speakers in manual setup after running AUTO SETUP.
No one records things anymore?
